No configured interfaces were found
galaxy
Hey guys,
I'm having an issues getting FreeNAS to pick up the network interface in on a Gigabyte GA-H77M-D3H. I've installed FreeNAS onto a USB stick and once it's booted up, it goes to the console and instead of giving me an IP address, it says "No configured interfaces were found. Try to do it manually".
The chipset is an Atheros GbE LAN. I've searched high and low for a solution but cant seem to find anything.
Any help would be greatly appreciated
Cheers.
D
dlavigne
Guest
From the initial setup menu, select "9) Shell" and type "ifconfig". Post that output here.
galaxy
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 19384
        options=3<RXCSUM, TXCSUM>
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3
        inet6 ::1 preficlen 128
        nd6 options=3<PERFORMUND,ACCEPT_RTADV>
D
dlavigne
Guest
That definitely did not find any interfaces...
If you type "dmesg" from the same prompt, does it have any probe lines for the Ethernet?
galaxy
If i "dmesg | grep -i network", i get:
WARNING: VIMAGE (virtualised network stack) is a highly experimental feature.
pci2: <network, ethernet> at device 0.0 (no driver attached)
D
dlavigne
Guest
Definitely no driver for that device. You could try booting into 9.1-BETA to see if it was added in FreeBSD 9.1.
galaxy
Does that mean i need a pci/pci-e NIC? Any recommendations on cards that work? Is there any way of injecting drivers into FreeNAS?
survive
Behold the Wumpus
Hi galaxy,
Yes, that board uses the Atheros network chipset which is why it doesn't work. Hard to believe they use that when there's a perfectly good Intel NIC built into the chipset....or to look at it another way, that chipset is cheaper than the Intel "PHY" (physical component interface) that you need to use the built-in Intel NIC.
Tha said, the NIC you linked to is actually mis-labeled in the title, that's not a 1000/GT card...lower down the listing describes the card as an Intel 1000/CT which is the exact card that is usually recommended to solve issues like you are having. You might want to search for the 1000/CT and see if you can find a properly listed one that might be cheaper but $35.00 US is about right (no idea how that exchanges into AU money).
-Will
galaxy
Hi Will,
Thanks for the advice! I've gone and purchased that one, seems to be the cheapest one anyway.
Yeah, i found it strange that they used a 3rd party chipset too. Stupidly, i just assumed it would have an intel chipset ethernet adapter :/
I'll see how it goes with the new NIC.
Thanks again!
Yatti420
Hmmm... This seems odd to me.. What revision is the motherboard? I doubt this would have any issue but mine seems to work fine I believe its v1.0... http://ca.gigabyte.com/products/product-page.aspx?pid=4143#sp GA-H77M-D3H..
It does have the atheros but im not sure why nothing installed corectly? I know freenas would of probably errored out by now just seems odd to me.. I don't believe I had to do anything to setup the atheros.. Running 8.3.1 x64 here.. Motherboard shipped with F6 - I just updated to F9 stable bios for this board..
Did you have onboard lan disabled in bios when you installed freenas?
Edit: My signature is incorrect.. I confirmed it is the GA-H77M-D3H .. I pulled the box from my closet.. Confirmed rev1.0
Copyright (c) 1992-2012 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
        The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 8.3-RELEASE-p6 #0 r248141M: Sun Mar 10 16:35:05 PDT 2013
    root@build.ixsystems.com:/home/jpaetzel/8.3.1-RELEASE/os-base/amd64/tank/hom        e/jpaetzel/8.3.1-RELEASE/FreeBSD/src/sys/FREENAS.amd64 amd64
Timecounter "i8254" frequency 1193182 Hz quality 0
CPU: Intel(R) Pentium(R) CPU G630 @ 2.70GHz (2693.90-MHz K8-class CPU)
  Origin = "GenuineIntel"  Id = 0x206a7  Family = 6  Model = 2a  Stepping = 7
  Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,C        MOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
  Features2=0x59ae3bf<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,EST,TM2,SSSE3,CX16,xT        PR,PDCM,PCID,SSE4.1,SSE4.2,POPCNT,TSCDLT,XSAVE>
  AMD Features=0x28100800<SYSCALL,NX,RDTSCP,LM>
  AMD Features2=0x1<LAHF>
  TSC: P-state invariant
real memory  = 10737418240 (10240 MB)
avail memory = 10246242304 (9771 MB)
ACPI APIC Table: <ALASKA A M I>
FreeBSD/SMP: Multiprocessor System Detected: 2 CPUs
FreeBSD/SMP: 1 package(s) x 2 core(s)
cpu0 (BSP): APIC ID:  0
cpu1 (AP): APIC ID:  2
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ioapic0 <Version 2.0> irqs 0-23 on motherboard
kbd1 at kbdmux0
hpt27xx: RocketRAID 27xx controller driver v1.0 (Mar 10 2013 16:34:54)
cryptosoft0: <software crypto> on motherboard
aesni0: No AESNI support.
acpi0: <ALASKA A M I> on motherboard
acpi0: [ITHREAD]
acpi0: Power Button (fixed)
acpi0: reservation of 67, 1 (4) failed
Timecounter "ACPI-fast" frequency 3579545 Hz quality 1000
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x408-0x40b on acpi0
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
vgapci0: <VGA-compatible display> port 0xf000-0xf03f mem 0xf7800000-0xf7bfffff,0        xe0000000-0xefffffff irq 16 at device 2.0 on pci0
pci0: <serial bus, USB> at device 20.0 (no driver attached)
pci0: <simple comms> at device 22.0 (no driver attached)
ehci0: <EHCI (generic) USB 2.0 controller> mem 0xf7e14000-0xf7e143ff irq 16 at d        evice 26.0 on pci0
ehci0: [ITHREAD]
usbus0: EHCI version 1.0
usbus0: <EHCI (generic) USB 2.0 controller> on ehci0
pcib1: <ACPI PCI-PCI bridge> irq 16 at device 28.0 on pci0
pci1: <ACPI PCI bus> on pcib1
pcib2: <ACPI PCI-PCI bridge> irq 16 at device 28.4 on pci0
pci2: <ACPI PCI bus> on pcib2
alc0: <Atheros AR8151 v2.0 PCIe Gigabit Ethernet> port 0xe000-0xe07f mem 0xf7d00        000-0xf7d3ffff irq 16 at device 0.0 on pci2
alc0: 11776 Tx FIFO, 12032 Rx FIFO
alc0: Using 1 MSI message(s).
alc0: 4GB boundary crossed, switching to 32bit DMA addressing mode.
miibus0: <MII bus> on alc0
atphy0: <Atheros F1 10/100/1000 PHY> PHY 0 on miibus0
atphy0:  none, 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT-FDX, 10        00baseT-FDX-master, auto, auto-flow
alc0: Ethernet address: 90:2b:34:65:52:f2
alc0: [FILTER]
pcib3: <ACPI PCI-PCI bridge> irq 18 at device 28.6 on pci0
pci3: <ACPI PCI bus> on pcib3
pcib4: <ACPI PCI-PCI bridge> irq 18 at device 0.0 on pci3
pci4: <ACPI PCI bus> on pcib4
rl0: <RealTek 8139 10/100BaseTX> port 0xd000-0xd0ff mem 0xf7c00000-0xf7c000ff ir        q 18 at device 0.0 on pci4
miibus1: <MII bus> on rl0
rlphy0: <RealTek internal media interface> PHY 0 on miibus1
rlphy0:  10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, auto
rl0: Ethernet address: 00:40:f4:72:34:52
rl0: [ITHREAD]
ehci1: <EHCI (generic) USB 2.0 controller> mem 0xf7e13000-0xf7e133ff irq 23 at d        evice 29.0 on pci0
ehci1: [ITHREAD]
usbus1: EHCI version 1.0
usbus1: <EHCI (generic) USB 2.0 controller> on ehci1
isab0: <PCI-ISA bridge> at device 31.0 on pci0
isa0: <ISA bus> on isab0
ahci0: <Intel Panther Point AHCI SATA controller> port 0xf0b0-0xf0b7,0xf0a0-0xf0        a3,0xf090-0xf097,0xf080-0xf083,0xf060-0xf07f mem 0xf7e12000-0xf7e127ff irq 19 at        device 31.2 on pci0
ahci0: [ITHREAD]
ahci0: AHCI v1.30 with 6 6Gbps ports, Port Multiplier not supported
alc0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=c3098<VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MCAST,WOL_MAGIC,VLAN_HWTSO,LINKSTATE>
        ether 90:2b:34:65:52:f2
        inet 192.168.0.125 netmask 0xffffff00 broadcast 192.168.0.255
        media: Ethernet autoselect (1000baseT <full-duplex,master>)
        status: active
rl0: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=3808<VLAN_MTU,WOL_UCAST,WOL_MCAST,WOL_MAGIC>
        ether 00:40:f4:72:34:52
        status: no carrier
        options=3<RXCSUM,TXCSUM>
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x5
        inet6 ::1 prefixlen 128
        nd6 options=3<PERFORMNUD,ACCEPT_RTADV>
        ether 02:6e:4b:ef:f0:00
        maxage 20 holdcnt 6 proto rstp maxaddr 100 timeout 1200
        member: alc0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 2 priority 128 path cost 20000
        member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 7 priority 128 path cost 2000
epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=8<VLAN_MTU>
        ether 02:c2:ca:00:07:0a
        status: active
Yatti420
It looks like the rev1.o labelled Atheros GBE Ethernet loading AR8151 drivers.. Rev1.1 looks like Atheros AR8161 which doesn't appear to have drivers.. A heads up to anybody thinking about using Gigabyte GA-H77M-D3H.
Added for search : Gigabyte GAH77MD3H - Atheros driver for Atheros 8161/ Atheros 8162.. ALC 8161 / ALC 8162 . This seems to be an actual hardware revision on the motherboard..
brian boyer
i am having the same issue. i had freenas installed on my hp prliant ml350 g5 and it was up and running but i wanted to have my 32 gb flash drive back so i put a 16 gb flash drive in and reinstalled frenas but now it is giving me the no configured interface error.
Locking this thread. There is no reason to ressurect a thread that is 18+ months old. If you wish to continue this discussion please create a new thread (and please follow the forum rules for thread creation).
