I have been trying to solve this for some time now but so far no luck. The situation is this.
I share the files on my FreeNAS box using NFS. Mounting the shares and everything seems to work as intended (I can edit, change and delete file and directories as I like) with the exception of one problem. I have my music library stored on the NAS and would like to normalize the volume of all the files. To do so on my main PC (an Arch Linux installation) I use
> find ./Music/ -iname *.mp3 -execdir mp3gain -c -p -r -k {} \;
which works just fine as long as I have the files on a local disk. However when I try to execute the same command on the mounted NFS share the program is able to analyse the file but for some reason can't apply the change (hangs). Running the command above as a superuser yields the following message.
"Can't open 01 Scissorlips.mp3 for modifying." Which I don't understand because it even happens with the following permission settings
> -rwxrwxrwx 1 rendagar torrent 5484254 Sep 16 18:07 01 Scissorlips.mp3
Also trying applying mp3gain directly on the file (so not using find) shows the exact same results. The relevant fstab entry for the mount is:
> 0.0.0.0:/mnt/mainPool/Music/ /mnt/nas/Music nfs user,rw,noauto,nolock,intr 0 0
(Not the actual IP)
I suspect the problem is due to some form of permissions I'm not aware of however I'm stumped. I hope anyone has any idea what is going on.
(Not the actual IP)
