NFS Issues - chown command return invalid argument
yucong111
truenas provides two directory for nfs client (different client)
/mnt/dev1/docker
/mnt/dev1/jenkins
truenas nfs /etc/exports
root@freenas[/mnt/dev1/jenkins]# cat /etc/exports
V4: / -sec=sys
/mnt/dev1/docker -maproot="root" 192.168.10.120 192.168.10.121 192.168.10.122 192.168.10.123 192.168.10.124 192.168.10.125 192.168.10.126 192.168.10.127
/mnt/dev1/jenkins -maproot="root" 192.168.3.106
The problem is 192.168.10.120~127 mount the directory and execute command chown is ok, but 192.168.3.106 execute command return error.
192.168.10.120:
[root@node1 docker]# chown root.root 1111
192.168.3.106:
[root@localhost jenkins_home]# chown root.root 111
chown: changing ownership of ‘111’: Invalid argument
Two nfs client system is centos7 , and mount info:
192.168.10.16:/mnt/dev1/jenkins nfs4 11668940544 261888384 11407052160 3% /var/jenkins_home
192.168.10.16:/mnt/dev1/docker nfs4 11755954560 348896128 11407058432 3% /docker
Nfs server is already set 'NFSv3 ownership model for NFSv4'. All the settings are the same, and all the nfs client mount is also based on the nfsv4 protocol. Why do some clients return error?
anodos
Sambassador
What client and server versions? Try turning up logging on NFS server and client and maybe see what op is actually failing. Maybe also use strace or truss to see what syscall is failing with EINVAL.
yucong111
Hi,This may be a mount error, I restarted the client machine and mount again, this time there is no error
