I’m trying to debug a NFS client problem and my basic understanding of FreeNAS internals it that at system boot the configuration is in essence split between some static settings in /etc/rc.conf and dynamic settings in /etc/rc.conf.local. In the later case, these come from interrogating the FreeNAS internal configuration DB.
In std FreeBSD, you could check the relevant nfs server settings in r.conf, which might be for example:
Obviously, you can check what daemons are running in FreeNAS and
The settings dealing with the NFS server seem to be handled in the
where are these values being echoed to, and how can they be displayed?
rpc_lockd_enable="YES" rpc_statd_enable="YES" rpcbind_enable="YES" nfs_access_cache=0 nfs_server_flags="-r -a -t -n 4" nfs_server_enable="YES" mountd_enable="YES" idmapd_enable="NO"
sysctl -a | grep string
gives the value of “vfs.nfsd.enable_stringtouid“, but what about other settings?The settings dealing with the NFS server seem to be handled in the
_gen_conf()
function of the FreeNAS /etc/rc.conf.local script. But when you see lines like these:Code:
echo "nfsv4_server_enable=\"YES\"" echo "nfsuserd_enable=\"NO\"" echo "nfsuserd_flags=\"-manage-gids\""
