SOLVED Nextcloud plugin and Nginx Proxy Manager configuration problem
theomolenaar
Hi. I'm having a problem making a secure connection (HTTPS) from a public DNS to a locally installed Nextcloud plugin (version 23.0.0). I'm using Nginx Proxy Manager 2.9.12 with Portainer inside an Ubuntu VM. The Ubuntu VM is hosted on TrueNAS.
Ports 80 and 443 are opened in my router. I know NPM is working with another public DNS record (somesubdomainname.duckdns.org). Unfortunately I can't create a new subdomain with duckdns because of this error:
So I registered a new subdomain at https://freedns.afraid.org.
Back in NPM I have set up a new Proxy host entry with this new Domain name. As an example (due to privacy) somesubdomainname.mooo.com).
After saving Letsencrypt will make an SSL certificate. As you can see the status for this new domain is Online.
For Nextcloud I was told I needed to change some settings in:
/usr/local/www/nextcloud/config/config.php
The yellow part is the public domain somesubdomainname.mooo.com. The same I used inside NPM.
Trusted proxies is the local ip for NPM.
Any ideas on how to get an HTTPS connection with this setup?
It may be worth knowing that duckdns automatically creates the *.domain.duckdns.org record, so you already have all possible subdomains pointing at your IP from duckdns.
You need to do a little more searching on config.php setups for reverse proxy and edit many more of the settings to make https the returned url/protocol.
Patrick M. Hausen
theomolenaar
Allright. I found a solution.
The first issue was that I didn't select NAT when installing the nextcloud plugin. I followed this video where Kevin Stevenson explained all the steps involved : https://www.youtube.com/watch?v=hxSAGY5zRwQ
As sretalla pointed out I could use a subdomain with duckdns. So that's what I did.
You may get a 400 error " The plain HTTP request was sent to HTTPS port "
To fix this do this in NPM:
