theomolenaar
 - Jun 12, 2016
Hi. I'm having trouble installing the latest Nextcloud plugin. Probably some certificate issues. Any ideas how to fix?
Installed the NC plugin on CORE without using NAT/DHCP.
I tried installing plugin version 22.2.3 last week and was hoping the 23.0.0. would magically fix the issue
The log below mentions this:
I watched some Youtube videos about installing nextcloud (plugin version) and searched this forum but had no luck in finding a working solution. Although this thread popped up in my search results: https://www.truenas.com/community/t...ou-build-your-private-cloud.95869/post-663360
Same issues but no mention how it got fixed.
The letsencypt.log contains the line 'No certificates found'. Might be something going on with Certbot?
What I did was installing this file on my iMac ( in Keychain Access) but the problem of not being able to run nextcloud was still there.You can install the following CA on your devices to trust the TLS certificate: /usr/local/etc/letsencrypt/live/truenas/root.cer
A few lines down:2021-12-05 10:10:58,004:DEBUG:certbot._internal.display.obj:Notifying user: No certificates found.
Generating a RSA private key
writing new private key to '/usr/local/etc/letsencrypt/live/truenas/root.key'
writing new private key to '/usr/local/etc/letsencrypt/live/truenas/server.key'
This is the installation log of Nextcloud (local ip adresses removed for security);Getting CA Private Key
Install Notes:
Saving debug log to /var/log/letsencrypt/letsencrypt.log
Signature ok
subject=O = TrueNAS (Nextcloud), CN = localhost
nginx_enable: -> YES
mysql_enable: -> YES
php_fpm_enable: -> YES
redis_enable: -> YES
fail2ban_enable: -> YES
Performing sanity check on nginx configuration:
Starting nginx.
Performing sanity check on php-fpm configuration:
Starting php_fpm.
Starting mysql.
Starting redis.
Starting redis.
mysqladmin: [Warning] Using a password on the command line interface can be insecure.
Starting redis.
Warning: Since password will be sent to server in plain text, use ssl connection to ensure password safety.
Starting redis.
mysql: [Warning] Using a password on the command line interface can be insecure.
Nextcloud was successfully installed
Set mode for background jobs to 'cron'
System config value trusted_domains => 1 set to string 192.168.x.xx
contacts 4.0.6 installed
contacts enabled
calendar 3.0.1 installed
calendar enabled
notes 4.2.0 installed
notes enabled
deck 1.6.0 installed
deck enabled
spreed 13.0.0 installed
spreed enabled
mail 1.11.0 installed
mail enabled
Server ready
Admin Portal:
