Hi Guys,
i have a Problem with upgrade nextcloud over major versions. But i'm not fit in docker or k3s
First the base versions:
TrueNAS-SCALE-22.02.4
Nextcloud 25.0.4 Docker 1.6.19 Tiny installation with only 2Gig
I started the Upgrade to 1.6.30 Nextcloud 27.0.0 over the Apps in Truenas Apps Frontend, all work fine. After some hours the nextcloud stay in maintenance mode and i removed it with the occ command and want to update it per web or occ. But after try to update i become the error that i cant upgrade from v25 to v27 "Exception: Updates between multiple major versions and downgrades are unsupported."
Now i want to rollback the version every time i want to roll back the roll back the interface hang up and nothing with the docker work.
Now the big question, how can i upgrade from 25 to 27? Or how can i install v26? Or how can i reinitiate the update in Docker? I think the dockerupgrade will update this major versions but i dont know how to restart it. Is there a way to rescue this docker image?
