Simon Pierre Desrosiers
- May 20, 2016
I have not used my next cloud plugin in a while. Since I needed it, I decided to upgrade it through the gui.
I updated the NAS to the latest 11.2-U7, then stoped the plugin and updated it.
When it started, I was presented with a page with a button to update which did not work (complaining of a cross site attack ?) (Sorry I do not have a screen shot). But the page also provided the possibility to run the command in the installation folder :
Which I did. The instruction are not very good, but I eventually figured out that I needed to run
Then it runs but spits out the following message :
So, Apparently, my installation was too old ( I have this in my
So, how can I update my plugin ? without loosing my nextcloud setup ?
Thank you
./occ upgrade
sudo -u www php /usr/local/www/nextcloud/occ upgrade
root@nextcloud:/ # sudo -u www php /usr/local/www/nextcloud/occ upgrade The process control (PCNTL) extensions are required in case you want to interrupt long running commands - see http://php.net/manual/en/book.pcntl.php The current PHP memory limit is below the recommended value of 512MB. Nextcloud or one of the apps require upgrade - only a limited number of commands are available You may use your browser or the occ upgrade command to do the upgrade Set log level to debug Exception: Updates between multiple major versions and downgrades are unsupported. Update failed Maintenance mode is kept active Reset log level root@nextcloud:/ #
config.php : 'version' => '14.0.1.1',).So, how can I update my plugin ? without loosing my nextcloud setup ?
Thank you
