NextCloud Cron-Job isn‘t working.
benalbi
Hello everyone!
I want to enable the Cron-Job for nextcloud background activities, but unfortunately I can't get it to work...
I thought this command is going to work:
sudo -u www-data k3s kubectl exec -n ix-nextcloud --stdin --tty nextcloud-66c598859-6vklm -- php -f cron.php
Which returned:
Defaulted container "nextcloud" out of: nextcloud, init-postgresdb (init)
Console has to be executed with the user that owns the file config/config.php
Current user id: 0
Owner id of config.php: 33
command terminated with exit code 1
Then looked up, which user am i for the container:
sudo -u www-data k3s kubectl exec -n ix-nextcloud --stdin --tty nextcloud-66c598859-6vklm -- whoami
Which returned:
root
So now i know, that i need to change the user for the container to "www-data", but how is this possible?
I would greatly appreciate any help!
Kris Moore
SVP of Engineering
Administrator
I'd check if you can change those commands to run "su -l -c '<command here>" www-data" inside the container, I.E. as part of the "k3s kubectl exec command".
benalbi
Here is the output:
root@truenas[/]# k3s kubectl exec -n ix-nextcloud --stdin --tty nextcloud-66c598859-6vklm -- su -l -c 'php -f cron.php' www-data
This account is currently not available.
gorrunyo
Here is the output:
Did yo manage to execute this?
