FlyingHacker
- Jun 27, 2022
I am scoping out hardware for a TrueNAS Core build designed to support heavy video file use. (Projects on the order of a few hundred GB)
I was looking for opinions on a setup like such. I am not married to anything here, and am opening to suggestions.
AMD Ryzen 5 5600 Vermeer 3.5GHz 6-Core AM4 Boxed Processor - Wraith Stealth Cooler Included
Asrock x570 Phantom Gaming 4
https://www.asrock.com/MB/AMD/X570 Phantom Gaming 4/index.asp#Specification
This supports ECC RAM, which I would have 64 GB from the QVL
A pair of Samsung EVO M.2 drives - probably 256-512GB each
8 Toshiba N300 8TB NAS drives using the 6Gb SATA ports on the mobo. Would want RAID 5 or 6.
~800W power supply (80plus gold or better)
Case will be some 4U rackmount.
Will add a 10GigE ethernet card (Chelsio)
Should I be looking at something else for a ZIL?
Is this type of consumer grade mobo/cpu a terrible choice? Any other suggestions?
Thanks in advance.
Thanks in advance.
