Chris Hoeschen
- Aug 9, 2014
Ok I was all set to use a spare desktop with 8GB of RAM to build me a FreeNAS for home use. Currently I have several different drives mounted in a 2008 R2 server (also running on desktop class hardware) shared as separate shares. I store photos, ISOs, and documents on these drives so data that doesn't change much. My goal is to combine this all into 1 FreeNAS box and setup different datasets for photos, ISOs, documents, etc. with quotas (that way if I needed more space on one of those datasets I can up the quota and (if needed) reduced the quota on another.) I wanted something that can handle a drive failure without data loss as right now if I loose a drive I loose the data on that drive and need to restore from backup.
Like I said I was all set to build it with that hardware (drives are already on order) then I read the ECC vs Non ECC RAM post and that changed my mind. I'm now thinking I shouldn't switch over to FreeNAS until I get new hardware that supports ECC. I have the items suggested by Cyberjock in my wishlist waiting on more funds so I can order them. My build will consist of this:
Supermicro MBD-X9SCM-F-O
Intel Pentium G2030 3GHz (this differs from Cyberjock's suggusting of the G2020)
Kingston KVR1333D3E9SK2/16G ECC RAM
5 x 4TB WD Red
1 x 4TB Seagate (already in use, will reuse)
I will setup the drives into a 16TB RAID-Z2 array.
My questions are:
Is there a difference between the G2020 and G2030 proc that will cause an issue?
Is 16GB RAM enough? I know the suggestion is 1GB RAM for every 1TB of disk space but is that based off of usable disk space or total disk space? In my setup I will have 16TB of usable space but 24TB of total space.
Any other gotchas, tips, suggestions I need to know regarding the hardware and FreeNAS? I have built many computers before from the ground up so I'm not a noob when it comes to the hardware installs but I am a noob when it comes to FreeNAS.
5 x 4TB WD Red
My questions are:
