New Scale build review
kjnicoletti
Howdy. I am upgrading my 7 year old TrueNAS server. This will be a direct replacement, I am mainly hoping to 1 - increase available storage and 2 - get better Plex transcode performance while maintaining SMB performance. I appreciate any input.
The current box is running TrueNAS Core 12.2. I run 6 jails (Plex, Transmission, SABnzbd, Radarr, Sonarr, UniFi). This should stay the same - anything heavier I would run on my ESX server. Plex is/will be a max of 2 simultaneous streams. On the current box, Plex chokes trying to transcode 4K, I try to keep to only direct streaming. The SMB shares are for a home environment, only two light users. The backup share is one PC making nightly differential backups, fulls once per week.
My current storage is one pool, comprised of a single vdev, RAID-Z3 for 24.7 TB usable (64% used). I plan on staying with one pool - single vdev, RAID-Z2 on the new server's pool (~54TB usable).
Plex media6.5 TB
SMB shares3 TB
transmission2 TB
Veeam backup share4TB
Old NASNew NAS
MBSuperMicro X10SL7-F-OSuperMicro X11SCH-LN4F-O
CPUIntel Xeon E3-1241 v3 Haswell 4/8C 3.5/3.9GHzIntel Xeon E-2176G Coffee Lake 6/12C 3.7/4.7GHz
Memory4 x Crucial 8GB DDR3 ECC 1600 (PC3L 12800)4 x Black Diamond 16GB DDR4 ECC Unbuffered 2133 (PC4 17000)
CaseFractal Design Define R5 BlackFractal Design Define R5 Black
OS DriveSuperMicro SSD-DM016-PHI SATA DOMSupermicro SSD-DM032-SMCMVN1 32GB SATA DOM
ZFS Storage8 x Seagate IronWolf 6TB NAS Hard Drive 7200 RPM 128MB5 x Seagate 18TB Exos X18 7200 RPM 256MB
NICIntel X520-1 10 GbE SFP+Intel X520-1 10 GbE SFP+
PSUSeaSonic SSR-450RM 450WSeaSonic Focus GX-550, 550W 80+ Gold, Full-Modular SSR-550FX
The 10GbE is connected DAC to a MicroTik CRS305-1G-4SplusIN switch.
I am wondering if I made any hardware compatibility mistakes and also if going from 8 (RAID-Z3) to 5 (RAID-Z2) spinning drives will significantly affect performance. I am also considering whether I should max memory at 128GB or if that's overkill. I am hoping to use the iGPU to transcode with Plex. I am not 100% locked into TrueNAS Scale, but it seems like the future and I'd like to make the switch if I can.
Thanks!
kjnicoletti
Well, I placed the order today so I guess I'll let you know if I run into any issues :)
HTLover
I'm am contemplating this build. How is the CPU with 4k transcoding? any issues or suggestions with your usage so far?
