I currently have 1.2 TB of data (mostly media) sitting on a 2.1TB RAID6 on Debian.  Built on dumpster dive hardware, I have trouble pulling HD video off it with SAMBA without hiccups.  I am looking to replace it with freeNAS/ZFS because I like the success stories and a GUI would be nice for a change. As I get older the attraction of doing everything from the command line is fading.
I currently have 6x750G Seagate Barracuda drives, with some spares available. They are a little long in the
tooth, but with the available spares I think I will be OK with a RAIDZ2 until I can afford some newer drives.
I have a 4U rack case, generic, but with decent airflow and big quiet fans. I have a 680 Watt overclocker style (you know, all black and cool looking) PSU if I need that much power, or a 480W Corsair, which is a better supply if 480W is sufficient.
Price is my primary consideration.(at a given performance level, I am not interested in recommendations to use non-ECC or otherwise try to make non-appropriate hardware work)
Looking at the Asrock C2750D4I with 16G RAM (Crucial CT2KIT102472BD160B ECC), and trying to compare it with one of the i3/SuperMicro combinations. I got lost in the SuperMicro specifications, but the general feeling I got was that matching the performance of the 8 cores of the Avoton with an i3, especially when it will be running CIFS, and I would like to try out PLEX, might be difficult.
Also, I am looking at starting with a 6 Disk RAIDZ2, then building a second 6Disk RAIDZ2 with newer/bigger disk. I didn't see any of the i3 capable Supermicro boards with 12 SATA onboard, so that solution would require additional controller cards, again adding price.
So I have 2 questions:
1)Is there a Mobo/Processor combo that can perform as well as the ASrock for less money?
2)I plan to build with 16G RAM (based on 8G + 1G/TB), leaving room for 16G more for expansion. I really don't see this box ever storing more than 10 TB, but based on the 8+1/TB formula an array of 6 2TB drives (8TB usable) and an array 0f 6 3TB drives (12 TB usable) still fits in the 32G max of the board. I realize that PLEX or any other jailed apps will require memory above that formula. Is this 32G RAM limit likely to bite me?
Thanks for any advice you may have.
kamakazi
kamakazi
