I'm new to freenas, with this build being my first experience with the setup. While the setup process went pretty smooth I was disappointed by the read/write speeds of the share (both CIFS and FTP)
My Build:
asrock c2750d4i
32GB (4x 8GB) kingston memory
6x WD30EFRX
sandisk cruzer fit 16gb
Seasonic SSR-450RM
Node 304
I'm running all 6x disks in a RAID-Z2. All hard drives are connected to the intel SATA ports. All disks have passed the long smartctl tests. The system is connected to a RT-AC68U router running Asuswrt-Merlin and connected via cat6 cable. The router reports that the port is using full duplex. I've also tried swapping out the ethernet cable.
When I transfer a 2GB movie file from my gaming machine to the NAS, I get a transfer rate between 60-64MB/s. When transferring the same file from the NAS, I get a transfer rate of 75-80MB/s.
Is this transfer rate to be expected? In my research of this configuration I was expecting to get around 100MB/s.
My Build:
asrock c2750d4i
6x WD30EFRX
Seasonic SSR-450RM
Node 304
C:\Users\Chris\Desktop\jperf-2.0.2\bin>iperf.exe -c 10.0.1.250 -P 1 -i 1 -t 20 ------------------------------------------------------------ Client connecting to 10.0.1.250, TCP port 5001 TCP window size: 64.0 KByte (default) ------------------------------------------------------------ [268] local 10.0.1.49 port 52525 connected with 10.0.1.250 port 5001 [ ID] Interval Transfer Bandwidth [268] 0.0- 1.0 sec 50.0 MBytes 419 Mbits/sec [268] 1.0- 2.0 sec 64.3 MBytes 539 Mbits/sec [268] 2.0- 3.0 sec 64.0 MBytes 537 Mbits/sec [268] 3.0- 4.0 sec 63.8 MBytes 535 Mbits/sec [268] 4.0- 5.0 sec 64.3 MBytes 539 Mbits/sec [268] 5.0- 6.0 sec 64.4 MBytes 540 Mbits/sec [268] 6.0- 7.0 sec 64.4 MBytes 541 Mbits/sec [268] 7.0- 8.0 sec 64.1 MBytes 537 Mbits/sec [268] 8.0- 9.0 sec 64.6 MBytes 542 Mbits/sec [268] 9.0-10.0 sec 64.4 MBytes 540 Mbits/sec [268] 10.0-11.0 sec 64.3 MBytes 539 Mbits/sec [268] 11.0-12.0 sec 64.2 MBytes 539 Mbits/sec [268] 12.0-13.0 sec 64.0 MBytes 537 Mbits/sec [268] 13.0-14.0 sec 63.9 MBytes 536 Mbits/sec [268] 14.0-15.0 sec 64.2 MBytes 539 Mbits/sec [268] 15.0-16.0 sec 64.2 MBytes 539 Mbits/sec [268] 16.0-17.0 sec 64.0 MBytes 537 Mbits/sec [268] 17.0-18.0 sec 64.6 MBytes 542 Mbits/sec [268] 18.0-19.0 sec 64.5 MBytes 541 Mbits/sec [268] 19.0-20.0 sec 64.1 MBytes 538 Mbits/sec [ ID] Interval Transfer Bandwidth [268] 0.0-20.0 sec 1.24 GBytes 533 Mbits/sec
[root@Permanence ~]# dd if=/dev/zero of=/mnt/permanence_pool/Media/ddfile bs=204 8k count=10000 10000+0 records in 10000+0 records out 20971520000 bytes transferred in 35.223389 secs (595386205 bytes/sec [root@Permanence /mnt/permanence_pool/Media]# dd if=/dev/zero of=ddfile bs=1m co unt=20000 20000+0 records in 20000+0 records out 20971520000 bytes transferred in 38.986238 secs (537921099 bytes/sec)
