mjd1979
- May 4, 2012
Hello Everyone, I'm having trouble with a new build NAS. This is the spec:
Asus M5A78L-M LX with Athlon II X2 250 3.0 GHz
2 x Kingston DDR3 4GB 1333MHz PC3-10600
CoolerMaster Silent 550 case
CoolerMaster 450w / 12cm GX 80Plus Bronze PSU
6 x 500GB Sata II Hard drive
Verbatim PenDrive 4GB Micro Nano (for the OS)
I updated the mobo bios from a USB stick then went on the try and boot freenas.
It will not boot from the USB stick.
I've burnt the FreeNAS-8.0.4-RELEASE-p1-x64 image using 7-Zip and Win32DiskImager on Windows to a 2GB and a 4GB pendrive, neither work.
The boot order and USB config are set as per this document: http://doc.freenas.org/index.php/Burning_an_IMG_File
The guide says to check if the USB drive is UDMA compliant, does anyone have any experience with this?
Thanks.
Thanks.
