I want to build a NAS System with a low power consumption but which is also capable of maxing out gigabit LAN.
Here are the component I have choosen so far:
CPU: Intel Core i3-2120T, 2x2.6 GHz
Board: ASUS P8B75-M LX
RAM: G.Skill DIMM Kit 16GB PC3-10667U 2x 8GB
PSU: Super Flower Golden King Platinum 550W
The build should have 5 HDD so I choose the Asus Board, because it has 5 built in SATA Ports.
This build should be running 24/7 so the power consumption in idle should be realy low.
As HDD I found the Seagate SV35.5 with 3 TB which should have a very low power consumption in idle mode, I also found the WD Red 3TB which is designed to be used in a NAS-System.
My questions are:
Does anyone have any recommendations which of this two HDDs I should use?
Is there any problem using the 4k sector WD HDD in FreeNAS?
If you have any other recommendations for HDDs or other components please post them.
Regards.
My questions are:
Regards.
