LaserAllan
- Mar 25, 2017
So, my motherboard recently died, got a new one, this one doesn't even let me into BIOS. It stays at the "System Initialising" forever....
These are the memory modules I am using CT102472BD160B which are listed on QVL so they should work, I have tried with all of the 4 modules in the A1 slot. No difference there.
So here is my question to you guys, after much thought and such I would suffice to find a Supermicro 2U-3U chassiw with 12 3.5 inch bays, that also supports beeing modified into 2.5 inch bays.
I am perfectly fine with buying used gear, but I'd like to know which chassis you guys would suggest so suite my needs.
