yelledbett
- May 18, 2013
I attempted FreeNAS 11 years ago, I liked it but it didn't seem ready for prime time and had issues with my existing hardware. I decided to go with a hardware raid solution with esata. It has served me well, but is a ticking time bomb with five disks > 9yrs old and five disks >5yrs old. (The data is backed up to S3, but would rather not have to download it all).
I am going to attempt FreeNAS / TrueNAS core again now that it is more mature, and has significant advantages over a hardware raid.
Here is my parts list I have developed after a lot of reading and pulling my hair out. I would love feedback and any potential problems I might run into. I could add a m.2 slog drive if you guys think it would be worth it, but the board says it supports 2260 only. I also understand with this board I will have to flash the onboard LSI adapter to IT mode to make it work. I am very comfortable doing that so no problems there.
Supermicro Micro ATX DDR4 LGA 1151 Motherboards X11SSH-CTF-O
Intel Xeon E3-1275 Processors BX80677E31275V6
Noctua NH-L9x65, Premium Low-Profile CPU Cooler (65mm, Brown)
2 of Crucial 32GB Kit (16GBx2) DDR4-2133 MT/S (PC4-2133) CL15 dual ranked x4based ECC Registered Server Memory CT2K16G4RFD4213
Rosewill 4U Server Chassis/Server Case/Rackmount Case, Metal Rack Mount Computer Case with 12 Hot Swap Bays & 5 Fans Pre-Installed (RSV-L4412)
Corsair CX Series 750 Watt (2017) 80 Plus Bronze Certified Non-Modular Power Supply (CP-9020123-NA)
8 of Western Digital (HGST) 12TB Ultrastar DC HC520 SATA HDD - 7200 RPM Class, SATA 6 Gb/s, 256MB Cache, 3.5" - HUH721212ALE604
