Network suddenly stopped working
John M. Długosz
My file server vanished from the LAN, and when I reboot and watch the console (via IPMI) it says that no network interface is configured. I choose 1 from the menu, and the desired interface device igb1, and it asks me to confirm "reset". That's all it does: no choice of manual configuration or viewing of the information.
Choosing 9 (shell) and then ifconfig, I get (see screenshot attached).
Strange, it's not telling me the IP address. But, during bootup, it seems to have obtained one via DHCP just fine; I noticed an IP address go by that was in the expected subnet range. But I don't know how to review the boot log to go check in more detail.
The lights on the ports on both ends of the patch cord are on. It says "active" in ifconfig.
What am I missing?
Please help: I have no access to the file server at the moment.
DrKK
FreeNAS Generalissimo
First things first. Does it have an IP?
Two obvious ways to check this:
1) Go into your router, and look at the address assignments, see if you have one for the FreeNAS box
2) Download "fing" for your cell phone, run it on your wi-fi network, and if your FreeNAS has an IP, it'll tell you.
Sakuru
Choose #9 and run ifconfig.
John M. Długosz
The client list does not show any entry (IPv4 or IPv6) for the FreeNAS.
How can I review the boot log, to see what it reported after initializing the network? I thought I saw a reasonable IP address mentioned as it went by quite fast.
John M. Długosz
HELP! I don't know how to get this working again.
I bought a new Intel (genuine name brand) NIC and put it in, and disabled the on-board LAN.
I switched cables around and changed ports in the switch.
Now I get a network device name of "em0", but it behaves the same way: "No configured interfaces were found". Choosing (1) from the menu, it offers to Reset it, but nothing changes.
The indicator lights are on (speed=1000) on both the NIC and the switch for this connection.
ifconfig shows em0 is active, media autoselected at 1000baseT. But no IP addresses.
DrKK
If the indicator lights are on, you have a connection. To what have you connected this computer, sir? Your router? A switch? Who is providing the DHCP?
m0nkey_
Silly question, but have you tried setting a static IP address? Don't forge to set your default gateway and DNS addresses from the menu.
John M. Długosz
The menu item (1) only offers to "reset" the network connection. It never gets to anyplace where I might manually configure. Just answer Yes to the prompt, and it's back at the menu.
A gigabit switch.
DHCP is provided by the Arris appliance that comes with my broadband service.
John M. Długosz
More information:
With the current hardware configuration (Intel NIC card), I took out the FreeNAS USB stick and booted PartedMagic. It works with the network just fine, and I can open a Firefox browser and read web pages e.g. en.wikipedia.org. I can see it (both IPv4 and IPv6) in the Client List of the gateway router.
So, it is something odd about the FreeNAS installation, for sure.
wblock
Documentation Engineer
Yes. So say No to it, and it will let you configure the interface.
John M. Długosz
Update:
I reinstalled a fresh FreeNAS onto a new USB flashdrive, and Uploaded my configuration. I used a year-old file that I made, so as to avoid any corruption in the current USB stick. That has different woes now: I started a new thread for this.
m0nkey_
Stop what you're doing. The last thing you want to do now is introduce new variables which will only make matters worse. Re-installing and recovering from a config from a year old config isn't the way to fix this.
Did you even attempt to set a static IP address? @wblock advised on how to do this.
Jayden67
Please help, I seem to be experiencing the same issue as the OP; two nights ago my FreeNAS server dropped of the network. It has been up and running with no problems for months with no recent configuration changes. The server lost connection while backing up data to a recently configured QNAP TVS-EC1080 NAS using SyncBack, if that's of any relevance.
My FreeNAS server is connected by Ethernet cable to a Netgear Nighthawk router The network activity lights on the server and router are blinking, but FreeNAS is not getting an IP address. FreeNAS (and the Plex jail) have static IPs set in the router, but they're not showing in the list of connected devices. I do not have Fing, so installed nmap on Ubuntu and scanned my network. The results are the same; I see every device on the network except the FreeNAS server. The FreeNAS console shows the IP of 0.0.0.0.
I ran IFCONFIG from the shell as requested, but I don't have the Supermicro IPMI software. The output of the command is :
	status: no carrier
ipfw0: flags=8801<UP,SIMPLEX,MULTICAST> metric 0 mty 65536
	 options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
	 inet6 ::1 prefixlen 128
 	inet6 fe80::1%lo0 prefixlen 64 scopeid 0xc
	 ether 02:d7:3b:66:55:00
	member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
	 	ifmaxaddr 0 port 14 priority 128 path cost 2000
epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
 	options=8<VLAN_MTU>
 	ether 02:d3:65:00:0e:0a
	 md6 options=9<PREFORMNUD,IFDISABLED>
 	status: active
Also on the following message is output to the FreeNAS console every 16 minutes and 2 seconds:
freenas ntpd_initres[2564]: host name not found: 0.freebsd.pool.ntp.org
freenas ntpd_initres[2564]: host name not found: 1.freebsd.pool.ntp.org
freenas ntpd_initres[2564]: host name not found: 2.freebsd.pool.ntp.org
I apologize if I have made any errors in the transcription.
The troubleshooting steps I have tried so far are rebooting the router and FreeNAS, and switching the ports the Ethernet cables are plugged into. On one reboot, FreeNAS got an IP address; I was able to log into the web GUI, but it dropped off the network again in less than an hour.
The last advice given in this thread was to try setting a static IP from the FreeNAS console. How do I do that?
I selected “1” from the menu and it gives me a choice of 1) igb0 and 2) igb1 I assume this is because I have multiple Ethernet ports. I then select option “1”, “N” for the Reset Network Configuration and “Y” for Configure IPv4 question. But I don't know what to enter next for the Interface Name.
m0nkey_
	status: no carrier
	 options=8<VLAN_MTU>
	 status: active
Please create your own thread.
Snake3y3s
you had any further luck on this?
Jailer
Not strong, but bad
How many dead threads are you going to revive? Start your own thread with your own question.
