First of all I have 2 NIC's in my FreeNAS box - they are configured for LACP. This works without issues.
After starting the Plugins Jail bridge0 and epair0a adapters are created - after this I can't reach the FreeNAS box at all - this can be solved by configuring the bridge0 adapter for DHCP via the console menu - but have do be redone after every reboot witch is a bit annoying
Problem exists in all 8.3 Beta's (not shure if it worked correctly in 8.2)
ifconfig:
Any way to fix this?
ifconfig:
re0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=2099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC> ether xx:xx:xx:xx:xx:xx media: Ethernet autoselect (1000baseT <full-duplex>) status: active re1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=2099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC> ether xx:xx:xx:xx:xx:xx media: Ethernet autoselect (1000baseT <full-duplex>) status: active lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=3<RXCSUM,TXCSUM> inet6 fe80::1%lo0 prefixlen 64 scopeid 0x5 inet6 ::1 prefixlen 128 inet 127.0.0.1 netmask 0xff000000 nd6 options=3<PERFORMNUD,ACCEPT_RTADV> lagg0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=2099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC> ether xx:xx:xx:xx:xx:xx inet 192.168.99.15 netmask 0xffffff00 broadcast 192.168.99.255 media: Ethernet autoselect status: active laggproto lacp laggport: re1 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING> laggport: re0 flags=18<COLLECTING,DISTRIBUTING> bridge0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether xx:xx:xx:xx:xx:xx inet 192.168.99.75 netmask 0xffffff00 broadcast 192.168.99.255 id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 100 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: lagg0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 6 priority 128 path cost 20000 member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 8 priority 128 path cost 2000 epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8<VLAN_MTU> ether xx:xx:xx:xx:xx:xx media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active
