First of all I have 2 NIC's in my FreeNAS box - they are configured for LACP. This works without issues.
After starting the Plugins Jail bridge0 and epair0a adapters are created - after this I can't reach the FreeNAS box at all - this can be solved by configuring the bridge0 adapter for DHCP via the console menu - but have do be redone after every reboot witch is a bit annoying
Problem exists in all 8.3 Beta's (not shure if it worked correctly in 8.2)
ifconfig:
Any way to fix this?
ifconfig:
re0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=2099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC>
ether xx:xx:xx:xx:xx:xx
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
re1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
status: active
options=3<RXCSUM,TXCSUM>
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x5
inet6 ::1 prefixlen 128
nd6 options=3<PERFORMNUD,ACCEPT_RTADV>
lagg0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
inet 192.168.99.15 netmask 0xffffff00 broadcast 192.168.99.255
status: active
laggproto lacp
laggport: re1 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING>
laggport: re0 flags=18<COLLECTING,DISTRIBUTING>
inet 192.168.99.75 netmask 0xffffff00 broadcast 192.168.99.255
maxage 20 holdcnt 6 proto rstp maxaddr 100 timeout 1200
member: lagg0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 6 priority 128 path cost 20000
member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 8 priority 128 path cost 2000
epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
status: active
