Network issue after updating to 23.10.1
f4lc0n
Hello Guys,
I've been to fix the network issue I'm getting since updating to 23.10.1. I initially thought that my issue was similar to this, but that solution did nothing.
I have a bare metal installation of TrueNAS SCALE and have been using that for about half a year now. Tried an upgrade from 22.12.4.2 to 23.10.0.1 and that's when all outgoing connections from this machine stopped working.
I am able to ping it without any issue and I can still access the ports 443, 53 (I have a pi hole instance running through pods) and I can SSH into it but I can't do any call out. I've tried pinging www.google.com but it gets a "Temporary failure in name resolution" error, which points to a DNS resolving issue. So I've tried to ping 8.8.8.8 or 1.1.1.1 and both gives me a "Destination Host Unreachable" error. I can't even ping my router via its IP anymore.
I'm not sure what information I can provide that would help to fix this, but what I have tried so far:
Using DHCP to get an IP and DNS setting (still same error)
Manually setting a new IP and setting the DNS (same error)
Change ethernet cable (same error)
Use a different port (which works fine, but still having the same error)
Tried fixing the date time in bios (same error)
Any help would be greatly appreciated.
Thanks
