From the network of this head tile, I don't have an additional I have 2.5GB/E
I turned off, I marked the empty enpXs0 on the empty and if I did on BR0 on static, I know it works but after starting it should automatically include the application operation at Kubernetes settings from the start network should connect and after starting the lack of connecting and U for zero IP works and the other under BR0 does not work I had to turn off every now and again, how to do it all the time
