Primo
- Nov 25, 2016
Hi all,
I am trying to copy files from a secondary server to my new TrueNAS scale server; I have mounted the network location and am running the "cp" command through shell:
Running the above command seemed to be working for the most part, but after finishing, I noticed that only half of the files had been copied. When trying to copy any of the files that did not get copied in the first run, I get the following:
Does anyone have any idea of what the issue could be based on the information provided?
sudo cp -r /mnt/NetworkShare /mnt/data/Media/VideoRunning the above command seemed to be working for the most part, but after finishing, I noticed that only half of the files had been copied. When trying to copy any of the files that did not get copied in the first run, I get the following:
zsh: unknown file attribute: 2Does anyone have any idea of what the issue could be based on the information provided?
