Hi
I have create 3 truenas scale systems. All of them with an additional interface in the same network.
I have also created an ad controller for ad join and reverse lookup.
The 3 truenas systems are part of the domain and the reverse lookup is established for each of the additional interfaces.
In my container based truecommand I can add the 3 truenas systems as expected.
All system can reach each other and lookup the ips.
Now its time to create a cluster within truecommand. Here is the part where I am failing. The network dropdown is empty. It is not possible to select any of the configured interfaces.
Any idea where the problem could be located or how to get some error details?
Regards
Lukas
admin@truenas-1[~]$ nslookup 10.1.1.181
181.1.1.10.in-addr.arpa name = truenas-1.truenas.local.
Regards
Lukas
