Network access problem for iocage jail
Itay1778
Hi, everyone
I have a problem I have not found a solution anywhere.
I installed nextcloud 13 with iocage jail by this guide https://forums.freenas.org/index.ph...ll-checks-passed-updated-to-use-iocage.61934/
But I installed with vnet (without it it would not have turned on)
My problem was that after I installed everything and everything worked fine I had to reboot to FreeNAS system and after the system was turned on I could not access the nextcloud through the browser in any way. I try to use both the local IP address and my domain and nothing and the browser shows that it can not connect. There is not even a server error like as IP is not connected but it is I try to ping through the jail I get 100% loss but with I try to ping through the FreeNAS itself So everything works fine and all my other services and all my other jail work without problems
I have access to this iocage jail through SSH and jexec
I have no idea what caused it suddenly after restart and I do not have access to the jail through the browser I tried to make a restart to the jail did not help
And I really do not want to make a new installation for all this jail and nextcloud and with I was doing it it probably will come back again the same problem after restarting to FreeNAS or power outage
Please have someone idea how to fix it !!
Itay1778
Itay1778
dir_d
I mean check Jail IP, /etc/resolv.conf within the jail, /etc/hosts within the jail, then ping out to make sure its ok. Make sure Apache is running if it is check MariaDB and the other services.
Itay1778
It's from nano /etc/resolv.conf
# Generated by resolvconf
search duckdns.org - It's just the weird thing that this is not my full domain
nameserver 192.168.1.110- My router
nameserver 1.1.1.1 - My DNS in my home
And it's from nano /etc/hosts
# $FreeBSD: releng/11.1/etc/hosts 109997 2003-01-28 21:29:23Z dbaker $
# Host Database
# This file should contain the addresses and aliases for local hosts that
# share this file.  Replace 'my.domain' below with the domainname of your
# machine.
# In the presence of the domain name service or NIS, this file may
# not be consulted at all; see /etc/nsswitch.conf for the resolution order.
::1					 localhost localhost.my.domain
127.0.0.1			   localhost localhost.my.domain nextcloud
# Imaginary network.
#10.0.0.2			   myname.my.domain myname
#10.0.0.3			   myfriend.my.domain myfriend
# According to RFC 1918, you can use the following IP networks for
# private nets which will never be connected to the Internet:
#	   10.0.0.0		-   10.255.255.255
#	   172.16.0.0	  -   172.31.255.255
#	   192.168.0.0	 -   192.168.255.255
# In case you want to be able to connect to the Internet, you need
# real official assigned numbers.  Do not try to invent your own network
# numbers but instead get one from your network provider (if any) or
# from your regional registry (ARIN, APNIC, LACNIC, RIPE NCC, or AfriNIC.)
192.168.1.27/24 nextcloud
I think everything looks right
I note in the instructions that it shows the jail creation command as:
iocage create -n yourjailsname ip4_addr="yourniccardname|your IP/network class handle 8,16,24" -r 11.1-RELEASE
If you did this:
ip4_addr="igb0|192.168.0.2/24"
Consider changing that to :
ip4_addr="vnet0|192.168.0.2/24"
as you went with vnet=on
You may be able to change it using:
iocage set ip4_addr="vnet0|192.168.0.2/24" yourjailsname
if it doesn't help, post the output of :
ifconfig
from your freenas console
Itay1778
If you did this:
ifconfig
I used it for installation and I mention that everything worked fine only after I restarted FreeNAS suddenly it did not work
iocage create -n nextcloud -r 11.1-RELEASE ip4_addr="vnet0|192.168.1.27/24" defaultrouter="192.168.1.110" vnet="on" allow_raw_sockets="1" boot="on"
Itay1778
ifconfig
em0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
		options=209b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC>
		ether e0:69:95:2b:bf:5c
		hwaddr e0:69:95:2b:bf:5c
		inet 192.168.1.1 netmask 0xffffff00 broadcast 192.168.1.255
		inet 192.168.1.26 netmask 0xffffff00 broadcast 192.168.1.255
		media: Ethernet autoselect (100baseTX <full-duplex>)
		status: active
		options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
		inet6 ::1 prefixlen 128
		inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2
		groups: lo
		ether 02:a1:c3:38:38:00
		groups: bridge
		member: vnet0:5 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
				ifmaxaddr 0 port 4 priority 128 path cost 2000
vnet0:5: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
		description: associated with jail: nextcloud
		options=8<VLAN_MTU>
		ether 02:ff:60:ba:b5:81
		hwaddr 02:53:90:00:04:0a
		nd6 options=1<PERFORMNUD>
		status: active
		groups: epair
Seems you are specifying the netmask in your resolv.conf which is not required:
should be:
192.168.1.27 nextcloud
You could also look at posting back the output of ifconfig... I expect to see that vnet0 is not properly bridged... we can fix that.
Also you are using a public address space in your home????
You mention 1.1.1.1 as your home DNS... this address space is public, not private. If it's working, i guess we don't need to solve it now, but you're asking for trouble there.
OK; you're too fast for me...
Yes, as I expected, your bridge0 is missing em0 as a member.
Try:
ifconfig bridge0 addm em0 up
Itay1778
should be:
Ok I'll fix up resolv.conf
And I sent the ifconfig
About my DNS https://1.1.1.1/ This great DNS is pretty new
Itay1778
Try:
It works!!!!!!!!!!!!!!!!!!!! Thanks for saving me
Itay1778
For a moment I thought I needed to reinstall everything
Thanks!!!!!
OK; I understand your point on 1.1.1.1 now... it's not "in your home", it's the one you forward to "for all devices in your home"... my misunderstanding.
If that ( ifconfig bridge0 addm em0 up) worked, you can add a tunable (actually 2) to do it at startup:
Type: RC
Variable: cloned_interfaces
Value: bridge0
Type: RC
Variable: ifconfig_bridge0
Value: addm em0 up
Itay1778
Type: RC
Value: bridge0
Type: RC
Value: addm em0 up
 RC: Command not found.
OK, I should have been more specific...
Tunables are in the Web UI (System/Tunables)
Hit the Add Tunable button and it should make sense from there...
Itay1778
I added it thanks :D
