I am building a FreeNAS server based on research done here, but still have questions regarding cabling.
I have the following equipment so far;
Supermicro SuperChassis 836BE16-R920B with a BPN-SAS2-836EL backplane and I plan on purchasing a HP H220 HBA.
I believe I need a SFF-8087 to SFF-8087 cable to connect the HBA to the SAS expander on the backplane.
Questions;
Is this the correct cable to connect the backplane to the SATA drives I'll use... likely WD Reds?
If so, is there any best practices on which front side ports to use for the connections? In other words, to connect to 16 drives I believe I'll need 4 breakout cables, do I connect those to ports 0 - 3 on the backplane or 0, 4, 8, 12 or ???
I'm sure I'll have additional questions, but I'll leave it at those for now.
Questions;
