Hi, I wanted to get your thoughts on how you would setup the pool based on the hardware and use case below:
Hardware
Hardware
- Motherboard supports 3 x pcie4 nvme m.2 drives, and I have 3 x 2TB pcie4 nvme m.2. drives right now.
- I also have 3 x 1TB crucial SATA SSD drives with DRAM
- Assume no limitations on SATA ports because my mobo has four SATA ports, miniSAS port, and a couple PCIE x16 slots where I can add HBA cards in the future. For what's worth, I'm boot pool is on a single 250 GB SATA SSD.
- My personal, family, and certain work files have the highest importance, and I would like these files to be on nvme m2 with the fastest access (I have 10 Gbps setup and I do have external backups). They total 500 GB at this moment and will grow over time.
- I will run a couple window virtual machines; at least one might be on 24/7; I can afford losing these virtual machines and rebuild them as needed.
- In Scale, I will run plex and other applications on TrueCharts
- For the important files, I can't decide whether to do raidz1 on 3 x 2TB nvme m2 OR do a mirror with 2 x 2TB nvme m2 drives. How would you do it?
- I was told the VMs should be on fast drives. Should I allocate 1 x 2TB nvme m2 just for the windows VMs? I feel that 2TB might be a waste because I will likely have the VMs to write data onto some spinning rusts (I have several WD Red 14TB)
- I was also told the applications should be on fast drives. Should I use the SATA SSD or nvme m2? What redundancy I should be thinking?
