erode
 - Dec 21, 2012
I've got the hardware, I just need to figure out the rest.  Is FreeNAS going to be able to handle running a VM for Plex to transcode? It uses ffmpeg which does not run in FreeBSD as far as I understand it.  Will the performance be better if I run the Linux VM inside FreeNAS, or would it be better if I ran FreeNAS in a VM on top of Linux?  Is that even possible since FreeNAS would have to manage a file system on top of a file system?
I hope to make a decision by tonight so I can get moving on this *finally*. Appreciate any advice you can give me.
Thanks
Specs:
Silverstone Temjin microATX enclosure
Silverstone 600w 80-Plus
ASRock Z77 Extreme-4m microATX
Intel i5-3470 w/ Intel 2500 HD
2x4GB DDR3-1600
2x3TB WD Red (5200rpm NAS)
2x150GB WD Velociraptor 10,000rpm (available, don't need to use them if unnecessary)
ATI 5870 1GB if necessary for encoding
Thanks
Specs:
2x4GB DDR3-1600
