I know you said you don't care about ROI, but really? Even a Pentium will suffice for "only FreeNAS & Plex", as long as you aren't transcoding more than 1 stream.
Both your quoted posts seem to contradict each other. Are you going to transcode a lot(2-4) or not ?
I see you post frequently, but I don't think anything I said warranted such a response.
Personally, I don't consider "2-4 streams" to be "a lot." Obviously, it's subjective. It seems like a typical scenario in a home environment. A majority of the time it won't be transcoding that many simultaneously, but I prefer that it can handle it when requested.
I've already purchased my processor and this thread can be marked "closed," but the purpose was to see what options there are. Xeons are kind of silly with the naming compared to desktop processors.
Let me break down what went into my decision. There were a few things that led to my final choice.
1) I'm overseas using military mail. There are size/weight restrictions. At some point, I will have to package it all back up and ship it to my next location. I wanted a case that could fit 8 drives, while also being as compact as possible. If I were home, I would have purchased another 24-bay rack mounted enclosure and a motherboard capable of two powerful Xeons, as I did last time.
2) There are a surprisingly small number of people selling bare NAS enclosures that aren't rackmount that I could find. I did not want a tower, again to keep it as small as possible, and also because I didn't want to set a large tower next to my Corsair 250D mini-itx water-cooled gaming rig. It can be argued that it's silly to care about aesthetics, but if I can without major sacrifices, I will. I decided on the U-NAS NSC-810A.
3) While reading other build threads, after creating this thread, I realized that there are few CPU coolers that fit well in that case. The recommended one had a max (recommended) TDP of 95w. I also learned that the max wattage PSU available for the case was 350w. This changed my CPU choices by making me have to consider TDP/performance. Of course, I like to leave some headroom and not go straight for 95w. A lot of the suggested CPUs, along with the ones I was considering, ranged from 95-135w making them a no-go. It also helped to limit TDP since the PSU options are limited.
4) Plex recommends a 2000 Passmark for a single high quality stream. For 4, I would need at least 8000. I believe Plex transcoding is multi-threaded, but I'm not positive, so to play it safe I wanted a CPU with at least 2000 on a single thread. This CPU addressed that, while the others didn't. Although Plex may not currently support all the latest hardware-accelerated transcoding features, I wanted a CPU that had them in case support is added in the future.
So in summary:
- I wanted to use the NSC-810A for case size, aesthetic, and 8-bays of storage. This limited the cooler options, which limited my max TDP options, which limited my CPU options.
- I wanted the CPU to support up to 2-4 Plex transcodes, which isn't a lot. For this I was looking for a CPU with single-threaded performance over 2000, and total performance over 8000.
- The processor I chose was purchased for $335, has a TDP of only 73w, has 2400 single-thread and 11000+ multi-thread performance, has all the latest hardware acceleration features for encryption and transcoding.
