first i tried to get support in the german forum, because i can give a better explanation. But the frequenz of users is very low. So i´ll try it with my limited english knowlegde here. Hope you understand!^^
First my List of Hardware:
Case: Mesh CD-01B-B
Powersupply: 350 Watt 80+
Mainboard: Intel DH67BL B3
CPU: Intel Core i3-2100T
RAM: 2GB DDR3 1333 Kingston
HDD: 3x 500GB WD-RAID Edition
HDD: 1x 500GB alternate frame for Backups
Compact-Flash to SATAII-Adapter with 4GB Sandisk-Card for FreeNAS
After some tries, FreeNas is working nice on this constellation. I configured FreeNAS like it was explained on the FreeNAS™ 8 Documentation Project.
- First i changed Login-PW, set right country, added Gateway and DNS.
- Then i added a User like my Win7 Account and added him to the group wheel.
- Next step was to make a Volume, took ZFS and RAIDZ and added a Dataset. Both; the Volume and Dataset, i gave full permissions to my User and Group.
- Then i activated CIFS as Local User without any other change and added a Windows-Share -> path to the Dataset, browable to Netwrokclients and good.
In the Network i find the Share but cant login. I took the right Name and PW.
First time i configured FreeNAS, there wasnt any login-window. I dont know what i changed but suddenly i could get access without any Login, had full permissions.
To understand why it now worked (without login but with access) i deleted every change on FreeNAS, step by step, to look when i would get no access anymore.
But the only way to stop accessing, was to delete the share. So i decided to start FreeNAS with default-Settings and try it again.
Now im on the same place, cant get access to the folder. Is there somebody who can give support for this?
It would be great, when you can explain shortly why to do things, so i can understand what i do there.
Hope of your help.
Svere
Huuuh...the RAM...2 GB for ZFS is bad....that was the reason i tried it first with UFS till someone said i should better use ZFS... dont think so, but can that be the Problem for me?
Case: Mesh CD-01B-B
Hope of your help.
Svere
