Navigating in RC1
Scrat_
Clicking the items down the left side mostly get no result. I've been needing to right click and 'open in new tab' to get where I wanna go. This was not an issue in beta 1 or beta 3 when I installed FreeNAS.
Sent from my SM-N950W using Tapatalk
D
dlavigne
Guest
Anything in /var/log/messages or /var/log/middlewared.log when it fails to navigate?
Also, which browser and browser version? Is it repeatable on a different browser?
Scrat_
I've been using the latest Chrome on OS X. I tend to use it over Safari cause it doesn't logout after a short bit of time. I'll check it when I get home after work.
Logs are something I haven't really bothered with as I don't think of it.. or know where they are most of the time.
Scrat_
Update: I tried it last night.. clicked _everything_. Couldn't get the problem to replicate. I'm sure it was the cache now.
FreeNAS has a very serious problem with crap from old versions being cached on the client and not automatically flushed by new versions. I had a frankenGUI at one point that was the new graphical elements with the old text where nothing worked. CTRL+F5 fixed that right away.
Scrat_
Ctrl+F5? On Mac I believe its Shift+F5.. which I tried.. in Chrome. I resorted to "open in new tab" for two days prior.
C'est la vie.
