Question about running script in jail
Joshua Walker
Im trying to run a python script from my jail but im getting no where. I installed python27 but when i type python, i get unknown command. So then I found that it was located in usr/local/bin/python2.7. When I run that, I fall into python. In my script, i add the path to the top of the script but now I get /usr/loc
al/bin: bad interpreter: Permission denied when run the script (/media/Scripts/myscript.py) /media/Scripts is a storage I added to the jail.
Sent from my SM-G950W using Tapatalk
Joshua Walker
ok so update to my situation
if i try to run
/media/script/myscript.py
i get permission denied
if i try
python2.7 /media/script/myscript.py
it works.
SweetAndLow
Sweet'NASty
did you give the script execute permissions? You also need a shebang in the script.
Joshua Walker
-rwxrwxrwx   1 media  wheel  10739 May 12 20:36 MediaMgmt_local.py
#!/usr/local/bin python2.7
SweetAndLow
Sweet'NASty
You use just pyrhon2.7 what is the full path? which python2.7 should show you.
SweetAndLow
Sweet'NASty
ahhh! is see what you did. There should not be a space between the /bin and python2.7. It should all be the same path to the executable. You can also just use /usr/local/bin/python, this is probably what i would do. No reason to force python2.7 especially since you should be working more in python 3 nowdays.
Joshua Walker
Ok.. I will give it a try. I also added a alias in the crsh file so I could use python instead of python2.7.
Joshua Walker
ok so i figured it out.
i removed my alias entry in the .cshrc, made a link
ln -s /usr/local/bin/python2 /usr/local/bin/python
, added
to env and put the shebang back to
#!/usr/bin/env python
and everything works
