nastest.local.nastest daily security run output "destroyed"
patrick sullivan
Hello
Just wanted a trained eye to glace at my report. Not real comfortable with the word "destroyed". :)
  • freenas.txt
myoung
I assume you are talking about this section:
 > GEOM_ELI: Device mirror/swap0.eli destroyed.
 > GEOM_ELI: Detached mirror/swap0.eli on last close.
 > GEOM_ELI: Device mirror/swap1.eli destroyed.
 > GEOM_ELI: Detached mirror/swap1.eli on last close.
 > GEOM_ELI: Device mirror/swap2.eli destroyed.
 > GEOM_ELI: Detached mirror/swap2.eli on last close.
Those are just swap partitions, nothing was lost nothing to worry about. It looks like just a normal reboot.
patrick sullivan
Thank you!!!
myoung
You can also see where they are recreated as the system boots back up.
 > GEOM_MIRROR: Device mirror/swap0 launched (2/2).
 > GEOM_MIRROR: Device mirror/swap1 launched (2/2).
 > GEOM_MIRROR: Device mirror/swap2 launched (2/2).
 > GEOM_MIRROR: Device mirror/swap3 launched (2/2).
 > GEOM_MIRROR: Device mirror/swap4 launched (2/2).
Chris Moore
Swap mirrors are always destroyed on shutdown and created on boot. It also puts the mirrors together in the order the drives come ready, so it is not always the same disks matched up.
Totally normal.
