Thanks for reading this post and I look forward to any helpful answers. Thanks in advanced.
I have been running FreeNAS for over a year Starting at version 9. I have upgraded as they have been released, but this time I ran into a slight problem and could use some direction on where this problem may exist.
I received a message that there is a new version so I clicked the option to update through the GUI using the Update tab. I applied the pending updates to 11.1-U1. This process appeared to be normal as it has in the past. I performed the reboot and that is where things went bad. The system loaded correctly as far as my boot volume is concerned. I was able to access my GUI, but my NAS volume was gone. Research online determine that I had lost my drives and needed to recreate the volume. I avoided that option. Assuming that my update had errors that I couldn't determine I ran this command from an SSH windows
Before anyone asks about the RAID card I am using. I did read the documents that state don't use hardware RAID. My drives are attached to the card, but each drive is configured individually as its own RAID-0. Without configuring them this way FreeNAS could not see the drives. I configured the system using ZFS now that they are seen and configured RAID Z1.
If you have thoughts I would love some info on how to determine what is causing my volume to fail? I am not that familiar with the logging in FreeNAS so if you can direct me to where the logs for this type of error may exist I am all ears.
GA-78LMT-USB3
AMD FX(tm)-4300 Quad-Core Processor
16 Gig RAM
Dell ADAPTEC 2610sa Pci-x SATA RAID Controller 6-port
RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
2 x PNY 16GB USB Drives
6 x 1TB WD drives
11.0-U4 Boot
11.1-U1
11.1-U1-1
freenas-update -v check && freenas-update --reboot -v update. This completed showing NO errors. I rebooted again and still my volume was gone. Fearing the worst, but happily I do keep backups of all my data, I used the GUI to revert back to my original version 11.0-U4 and to my surprise my volume came back. I tested my theory by updating again and the volume disappears. I revert back to my earlier version and its back.Before anyone asks about the RAID card I am using. I did read the documents that state don't use hardware RAID. My drives are attached to the card, but each drive is configured individually as its own RAID-0. Without configuring them this way FreeNAS could not see the drives. I configured the system using ZFS now that they are seen and configured RAID Z1.
GA-78LMT-USB3
16 Gig RAM
6 x 1TB WD drives
11.0-U4 Boot
11.1-U1
11.1-U1-1
