Added required info:
FreeNAS-9.3-STABLE-201505130355
1/2-ASRock C2750D4I Mini ITX Server Motherboard
3-(32GB total) Crucial 16GB (2 x 8GB) 240-Pin DDR3 SDRAM ECC Unbuffered DDR3 1600 (PC3 12800) Server Memory Model CT2KIT102472BD160B
4 -(3) Seagate Barracuda 7200.14 ST3000DM001 Raid-z1
-(1) Mushkin Enhanced Chronos Deluxe MKNSSDCR240GB-DX 2.5" 240GB (for Downloads/Jails)
5-N/A
6- On board server lan is plugged directly into router ( mi424wr from verizon )
ifconfig:
I managed to remote in via Jviewer and take a screenshot of the last thing on screen before it went completely black:
The configured interfaces makes me think its a network issue, but I was able to remote into the server viewer program so I am not 100% sure if it is.
Any ideas? Its currently showing a black screen, and it posted an error. This seems to happen a few times when deleting a few files 100+ GB off an SSD ( not an array just a ssd for jails and downloads )
Upon reboot it says my SSD was not found then started to auto import a new drive:
Edit:
WebGUI states:
"CRITICAL: The volume SSD (ZFS) state is UNKNOWN:"
My question is now, if the ssd that hosts the plugin's goes down why would that effect the server and not just the one drive?
5-N/A
ifconfig:
igb0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO>
ether d0:50:99:50:44:45
inet 192.168.1.5 netmask 0xffffff00 broadcast 192.168.1.255
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
igb1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether d0:50:99:50:44:46
status: no carrier
ipfw0: flags=8801<UP,SIMPLEX,MULTICAST> metric 0 mtu 65536
options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x5
Edit:
WebGUI states:
