hi,
I've spent the last few week researching and tinkering with freenas. I'm using the latest 8.3 p1.
I'm running it as a VM using esxi 5.1.
- 1 cpu, 1 core (as per docs)
- 4GB of RAM.
- 1 HD to store the FreeNAS image
- a 2nd 1TB HD for the ZFS volume. no datasets defined.
- 1 NIC - VMXNET2.
I know the main benefits of ZFS are things like it's raid capability etc, but I have a very simple setup and I backup important stuff to the cloud so I don't need a heavy local solution. My intention is to use it as a very simple file server setup.
As the title suggests I've been having all sorts of problems with this :(
1. Web GUI hangs randomly - The web gui will stop responding. It will just be stuck in a "waiting for ....". I'm using chrome for the browser, but found it doesn't matter much (as firefox doesn't seem to work at all). If i use Chrome's developer tools i can see the it sends a request for the page but doesn't receive a reply. If i inspect the nginx logs on freenas, i can see the logs report 200 for the requests. I try restarting the nginx service, but doesn't do anything. the only solution is a reboot of freenas. None of my searches are turning up any information from people experiencing similar issue.
2. Because I have mixed environment, the easiest test was just CIFS. I wanted to compare CIFS throughput to what I know i can get using a windows box. I was able to get it up to ~60MB/s avg on like 3GB total transfer with lk 1GB+ files. Not stellar, but acceptable. So I try playing back a wmv. WMP hangs. I have a network monitor widget thing and it tells me we are not getting any data. Windows explorer looks busy, but is still responsive. and after ~2 mins or so, reports to me that the share is no longer available. At this time also, it is typical that the web gui will also become unreachable. RAM and CPU utilization on the box is low. running top in freenas console shows no culprits.
3. Following above, I try deleting files. Well that was fun too. I got the similar symptom of Windows explorer looking busy with a win7 delete file dialog popped up saying "looking for files..." and then just sitting there. Again, after 2 mins, it just craps out saying the share is no longer available.
Please help. I can provide additional details if requested.
I'm mostly wondering if anyone recognizes these symptoms as "another N00B who didn't RTFM properly". If so please kindly point me at what I should've done and I'll be grateful.
Thanks in advance.
- 4GB of RAM.
- 1 NIC - VMXNET2.
Thanks in advance.
