So long story short;
I set up FreeNAS; it worked great for a few months; then it suddenly stopped..
It looked like I had some form of controller issue; but that appears to be cleared now... The box can see all 9 drives IIRC (3 lots of 3 drive raidz in a single zpool) it was one big pool...
However
I'm running
Please remember I'm a N00b on FreeNAS, but I'll try not to be frustrating.
I may ask a dumb question; But I'll learn from it :)
Thanks
However
zpool import returns nothing... If someone could help me try get the data back that would be really awesome...I'm running
FreeBSD 11.1-STABLE (FreeNAS.amd64) #0 r321665+e0c4ca60dfc(freenas/11.1-stable): Wed May 30 14:18:20 EDT 2018Code:
#glabel status Name Status Components label/efibsd N/A da0p1 gptid/c141efa0-3390-11e8-a29a-6805ca3b98e2 N/A da0p1 gptid/5bc501e9-35d9-11e8-8ed2-6805ca3b98e2 N/A ada0p2 gptid/8a1f3cc1-44e4-11e8-9e38-6805ca3b98e2 N/A ada1p2 gptid/5b29980b-35d9-11e8-8ed2-6805ca3b98e2 N/A ada2p2 iso9660/U3%20System N/A cd0 gptid/a855d718-561a-11e8-96a0-6805ca3b98e2 N/A ada3p2 gptid/aa98c801-561a-11e8-96a0-6805ca3b98e2 N/A ada4p2 gptid/a9b0d9ce-561a-11e8-96a0-6805ca3b98e2 N/A ada5p2 gptid/1edc2cef-646b-11e8-9cca-6805ca3b98e2 N/A ada6p2 gptid/b928e879-5623-11e8-857d-6805ca3b98e2 N/A ada7p2 gptid/890ee303-44e4-11e8-9e38-6805ca3b98e2 N/A ada8p2 gptid/5bbe7d4e-35d9-11e8-8ed2-6805ca3b98e2 N/A ada0p1
gpart show => 40 15682480 da0 GPT (7.5G) 40 532480 1 efi (260M) 532520 15149992 2 freebsd-zfs (7.2G) 15682512 8 - free - (4.0K) => 40 15628053088 ada0 GPT (7.3T) 40 88 - free - (44K) 128 4194304 1 freebsd-swap (2.0G) 4194432 15623858688 2 freebsd-zfs (7.3T) 15628053120 8 - free - (4.0K) => 40 7814037088 ada1 GPT (3.6T) 40 88 - free - (44K) 128 4194304 1 freebsd-swap (2.0G) 4194432 7809842688 2 freebsd-zfs (3.6T) 7814037120 8 - free - (4.0K) => 40 15628053088 ada2 GPT (7.3T) 40 88 - free - (44K) 128 4194304 1 freebsd-swap (2.0G) 4194432 15623858688 2 freebsd-zfs (7.3T) 15628053120 8 - free - (4.0K) => 40 15628053088 ada3 GPT (7.3T) 40 88 - free - (44K) 128 4194304 1 freebsd-swap (2.0G) 4194432 15623858688 2 freebsd-zfs (7.3T) 15628053120 8 - free - (4.0K) => 40 15628053088 ada4 GPT (7.3T) 40 88 - free - (44K) 128 4194304 1 freebsd-swap (2.0G) 4194432 15623858688 2 freebsd-zfs (7.3T) 15628053120 8 - free - (4.0K) => 40 15628053088 ada5 GPT (7.3T) 40 88 - free - (44K) 128 4194304 1 freebsd-swap (2.0G) 4194432 15623858688 2 freebsd-zfs (7.3T) 15628053120 8 - free - (4.0K) => 40 15628053088 ada6 GPT (7.3T) 40 88 - free - (44K) 128 4194304 1 freebsd-swap (2.0G) 4194432 15623858688 2 freebsd-zfs (7.3T) 15628053120 8 - free - (4.0K) => 40 7814037088 ada7 GPT (3.6T) 40 88 - free - (44K) 128 4194304 1 freebsd-swap (2.0G) 4194432 7809842688 2 freebsd-zfs (3.6T) 7814037120 8 - free - (4.0K) => 40 7814037088 ada8 GPT (3.6T) 40 88 - free - (44K) 128 4194304 1 freebsd-swap (2.0G) 4194432 7809842688 2 freebsd-zfs (3.6T) 7814037120 8 - free - (4.0K)
zfs list NAME USED AVAIL REFER MOUNTPOINT freenas-boot 1.68G 5.28G 64K none freenas-boot/ROOT 1.67G 5.28G 29K none freenas-boot/ROOT/11.1-U5 1.66G 5.28G 849M / freenas-boot/ROOT/Initial-Install 1K 5.28G 835M legacy freenas-boot/ROOT/Wizard-2018-03-29_13:53:48 1K 5.28G 836M legacy freenas-boot/ROOT/default 11.4M 5.28G 847M legacy freenas-boot/grub 7.02M 5.28G 7.02M legacy
Thanks
