Sphinxicus
- Nov 3, 2016
Hello All
After a lot of reading (including the hardware guide) I feel its time for me to put my potential build out there for review.
Main usage will be as home NAS with max 3 users to store video/image files and to serve movies to Kodi on a Raspberry Pi. So NFS and SMB.
Will also need to host the following VM's:
- OwnCloud(as I use that as a frontend for file storage/sharing)
- Zoneminder to caputure IP camera footage
These are currently running on a HP Gen 7 Microserver with local datastore, I would like to free this Server up for other duties.
Space is limited where i need to locate this, I have a 450mm deep rack enclosure (which is a nightmare for finding short depth cases) and have 1U free space currently.
So to the specs
If i free up space, potential Future expansion of number of drives to a short depth external JBOD enclosure via some form of SAS controller card (need to read up on this)
I know that the Asus board is not in the hardware guide. I had originally planned to go for the Asrock Rack E3C232D2I but I can get the above spec a great deal cheaper. I havent found any horror stories with this board and Freenas but to be fair, there doesnt seem to be a great deal of chat about it.
So there you are, feel free to critique my build.
Thanks for taking the time to read
So to the specs
- Motherboard - Asus P10S-I with ASMB8-IKVM for Remote management
- CPU - Xeon E1220 V5
- Heat Sink - Dynatron K199 1u Active Cooler
- Memory - 16GB RAM - 2 x Crucial 8GB DDR4 ECC (CT8G4WFD824A.18FB1)
- Boot Disk - 64GB SATA3 SSD (make/model escapes me) that I had been using as a cache disk in my PC
- Storage - 4 x 3TB WD Reds (leaning towards Z2 configuration rather than 2 mirrored pairs)
- Case - istarUSA M-140-ITX 1U Rackmount cse with 4 hotswap bays
- Powersupply - 250W Enhance 1U Flex ENP-7025B 80 Plus Bronze (Comes with the case)
