My first RED LIGHT!
{HD}
CRITICAL: June 21, 2017, 4:56 a.m. - Device: /dev/da8 [SAT], Self-Test Log error count increased from 0 to 1
I have it scheduled to do a 'Long Test' twice a month. It has since completed another 'Long Test' without error.
How do I find more data on the issue? How do I clear the error from the GREEN/RED Light indicator? I have unchecked it but it still shows up in the list...
{HD}
Paste the output of smartctl -a /dev/da8.
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:  Western Digital Red
Device Model:  WDC WD40EFRX-68WT0N0
Serial Number:  SeemsPrivate
LU WWN Device Id: 5 0014ee 262dcff83
Firmware Version: 82.00A82
User Capacity:  4,000,787,030,016 bytes [4.00 TB]
Sector Sizes:  512 bytes logical, 4096 bytes physical
Rotation Rate:  5400 rpm
Device is:  In smartctl database [for details use: -P show]
ATA Version is:  ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:  Sun Jul  9 21:14:01 2017 EDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00)   Offline data collection activity
		   was never started.
Self-test execution status:  (  0)   The previous self-test routine completed
		   been run.
data collection:	  (52320) seconds.
capabilities:		 (0x7b) SMART execute Offline immediate.
		   command.
		   Self-test supported.
SMART capabilities:  (0x0003)   Saves SMART data before entering
		   power-saving mode.
Error logging capability:  (0x01)   Error logging supported.
Short self-test routine
recommended polling time:	 (  2) minutes.
Extended self-test routine
recommended polling time:	 ( 523) minutes.
Conveyance self-test routine
recommended polling time:	 (  5) minutes.
SCT capabilities:	 (0x703d)   SCT Status supported.
		   SCT Data Table supported.
ID# ATTRIBUTE_NAME  FLAG  VALUE WORST THRESH TYPE  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate  0x002f  200  200  051  Pre-fail  Always  -  33
  3 Spin_Up_Time  0x0027  191  176  021  Pre-fail  Always  -  7425
  4 Start_Stop_Count  0x0032  100  100  000  Old_age  Always  -  18
  5 Reallocated_Sector_Ct  0x0033  200  200  140  Pre-fail  Always  -  0
  7 Seek_Error_Rate  0x002e  200  200  000  Old_age  Always  -  0
  9 Power_On_Hours  0x0032  092  092  000  Old_age  Always  -  6033
 10 Spin_Retry_Count  0x0032  100  253  000  Old_age  Always  -  0
 11 Calibration_Retry_Count 0x0032  100  253  000  Old_age  Always  -  0
 12 Power_Cycle_Count  0x0032  100  100  000  Old_age  Always  -  18
192 Power-Off_Retract_Count 0x0032  200  200  000  Old_age  Always  -  16
193 Load_Cycle_Count  0x0032  200  200  000  Old_age  Always  -  1380
194 Temperature_Celsius  0x0022  121  114  000  Old_age  Always  -  31
196 Reallocated_Event_Count 0x0032  200  200  000  Old_age  Always  -  0
197 Current_Pending_Sector  0x0032  200  200  000  Old_age  Always  -  0
198 Offline_Uncorrectable  0x0030  100  253  000  Old_age  Offline  -  0
199 UDMA_CRC_Error_Count  0x0032  200  200  000  Old_age  Always  -  0
200 Multi_Zone_Error_Rate  0x0008  200  200  000  Old_age  Offline  -  12
SMART Error Log Version: 1
No Errors Logged
Num  Test_Description  Status  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline  Completed without error  00%  6022  -
# 2  Extended offline  Completed without error  00%  5976  -
# 3  Short offline  Completed without error  00%  5926  -
# 4  Short offline  Completed without error  00%  5830  -
# 5  Short offline  Completed without error  00%  5782  -
# 6  Short offline  Completed without error  00%  5686  -
# 7  Short offline  Completed without error  00%  5590  -
# 8  Extended offline  Completed: read failure  80%  5584  1140798008
# 9  Short offline  Completed without error  00%  5494  -
#10  Short offline  Completed without error  00%  5398  -
#11  Short offline  Completed without error  00%  5315  -
#12  Extended offline  Completed without error  00%  5269  -
#13  Short offline  Completed without error  00%  5220  -
#14  Short offline  Completed without error  00%  5124  -
#15  Short offline  Completed without error  00%  5052  -
#16  Short offline  Completed without error  00%  4956  -
#17  Extended offline  Completed without error  00%  4862  -
#18  Short offline  Completed without error  00%  4764  -
#19  Short offline  Completed without error  00%  4668  -
#20  Short offline  Completed without error  00%  4572  -
#21  Extended offline  Completed without error  00%  4527  -
1 of 1 failed self-tests are outdated by newer successful extended offline self-test # 2
  1  0  0  Not_testing
  2  0  0  Not_testing
  3  0  0  Not_testing
  4  0  0  Not_testing
  5  0  0  Not_testing
m0nkey_
Continue to monitor it. I don't see anything really wrong with the drive, but SMART did report an error for some reason.
If I were you, I'd replace the drive anyway or at least have one spare in order to replace it when it does begin to fail.
Stux
Is the drive still under warranty?
And did you burn in the drive?
Stux
Burn in your spare. Then replace the drive with it. Then burn in the possibly faulty drive. If it fails, replace it with an RMA Otherwise chuck it. If it doesn't fail it's now your spare.
Stux
