Harold Scott
- May 27, 2014
Have I missed something
While copying my exported hyper-v guest machine directory structure from my hyper-v host machine I get item not found error complaining about the freenas destination.
At the point of the popup I can see that the destination folder has been created including the two files it would contain although files indicate zero length
The try again button only results in the same error.
if I choose skip, I'm next prompted if I want to overwrite the already existing zero length files, if I choose overwrite it seems the files are successfully copied.
the directory that causes the problem is named 72C67998-B73D-4279-B4DC-B77404A6BBB7
containing a xml file and a subdirectory of the same name, and that subdirectory contains a bin and vsv file of the same name.
copying the same material to a Microsoft machine works without any problems.
none of my machines are on a domain
