jgreco
Resident Grinch
- May 29, 2011
While the "separate network" is obvious for VMs and/or jails - do you know if other integrated "hyperconverged" products like Proxmox also apply that concept to sharing services? That's the one thing that always puzzles me in this recurring discussion. Are we talking VMs? Then TrueNAS is - although being a type 2 HV - no different from any other product out there. It's just the sharing that is lumped up with the management plane in a single stack.
Kind regards,
Patrick
Proxmox is not some magic thing. It is basically the same sort of product as TrueNAS; a prepackaged appliance OS whose purpose is primarily to run VM's, but includes ZFS as an afterthought. TrueNAS is a ZFS NAS that includes VM's/jails as an afterthought. You could turn those things around pretty easily.
From Wikipedia; see this article.
There's a lot of angst about "bare metal hypervisors" out there, but in practice, all of these things have weakened the boundaries between type 1 and type 2 hypervisors. A true type 1 hypervisor could be something akin to a system that used PCI virtual functions to let each guest directly interact with the hardware, and kept its fingers out of things other than to manage resource allocations. Since that's not desirable or practical, ESXi, KVM, and bhyve all present virtual devices and related abstractions such as switches/bridges, virtual disks (VMware has its VMFS, Proxmox and TrueNAS both have ZFS to power them), etc. This means that there's really almost always some OS layer in between the bare metal and the VM. VMware seems to be allowed with getting away with the claim that "oh that's not an OS, that's the ESXi hypervisor". This is vaguely true, but if you were to look at it via a lens of "it's just an (admittedly highly) specialized kernel" and "the management plane (i.e. userland) is clearly calling the shots", with a kernel that is intercepting all the networking and processing it through a software switch, and disk I/O through VMFS, ESXi starts to look much less than just a bare metal manager and a lot more like a ... type 2 hypervisor? Yup.
So, let me reset you on this: TrueNAS and Proxmox are both effectively Type 1 hypervisors by any reasonable modern analysis. They run their VM's with resources and scheduling managed within the kernel, as opposed to things like VirtualBox or FreeBSD jails which truly do operate in userland.
And if you're confused by this, let's not bring ESXi's new support for containers into the discussion.
Anyways, the Wikipedia article defines KVM to be a Type 1 hypervisor solution, so both Proxmox and TrueNAS are covered by that. Prickly folks will want to say "but Proxmox INTENDS to be a hypervisor" and "TrueNAS INTENDS to be a NAS" and try to argue things from that direction, but quite frankly what I see is "KVM offering up ZFS datastores with Linux networking and bridging" in both cases. I cannot see a real TECHNICAL case for calling TrueNAS a type 2 hypervisor if we call Proxmox and ESXi a type 1.
And of course you are completely correct that the sharing bits of TrueNAS are effectively on the management plane, sharing the IP networking of the host system.
