Multiple interfaces and shared IPs
listhor
My network setup looks as following:
GUI interface is at igb1 - 172.16.0.9.
igb2 is used as shared IPs NIC for jails, therefore it doesn't have assigned any IP - otherwise it won't accept jails IP assignment/alias. I don't know how or I'm not able to setup vlans following instructions in online manual. It simply doesn't work with jails (and maybe with Unifi hardware).
My problem is that main interface - igb1 (172.16.0.9, connected to untagged port) shows up (coming and going and sometimes stays longer) on switch clients list with IP assigned to one of jails (plex). And jail IP is shared IP assigned to other interface igb2, in other subnet (172.16.1.5, connected to tagged port, vlan11).
Config:
igb0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 9000
    description: LAN3
    options=6403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6>
    ether ac:1f:6b:d7:fb:c6
    hwaddr ac:1f:6b:d7:fb:c6
    media: Ethernet autoselect
    status: no carrier
vmx0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 9000
    description: storage net esxi
    options=60039b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,TSO4,TSO6,RXCSUM_IPV6,TXCSUM_IPV6>
    ether 00:0c:29:eb:9e:f5
    hwaddr 00:0c:29:eb:9e:f5
    inet 10.55.1.2 netmask 0xffff0000 broadcast 10.55.255.255
    status: active
vmx1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 9000
    description: SMB
    ether 00:0c:29:eb:9e:ff
    hwaddr 00:0c:29:eb:9e:ff
    inet 172.16.1.54 netmask 0xffffffc0 broadcast 172.16.1.63
    status: active
igb1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 9000
    description: LAN2
    ether ac:1f:6b:d7:fb:c5
    hwaddr ac:1f:6b:d7:fb:c5
    inet 172.16.0.9 netmask 0xffffff00 broadcast 172.16.0.255
    media: Ethernet autoselect (1000baseT <full-duplex>)
    status: active
igb2: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 9000
    description: LAN4
    ether ac:1f:6b:d7:fb:c7
    hwaddr ac:1f:6b:d7:fb:c7
    inet 172.16.1.2 netmask 0xffffffc0 broadcast 172.16.1.63
    inet 172.16.1.5 netmask 0xffffffc0 broadcast 172.16.1.63
    status: active
    options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
    inet6 ::1 prefixlen 128
    inet6 fe80::1%lo0 prefixlen 64 scopeid 0x6
    groups: lo
Routing tables
Internet:
Destination        Gateway            Flags     Netif Expire
default            172.16.0.1         UGS        igb1
10.55.0.0/16       link#2             U          vmx0
10.55.1.2          link#2             UHS         lo0
127.0.0.1          lo0                UHS         lo0
172.16.0.0/24      link#4             U          igb1
172.16.0.9         link#4             UHS         lo0
172.16.1.0/26      link#3             U          vmx1
172.16.1.2         link#5             UHS         lo0
172.16.1.5         link#5             UHS         lo0
172.16.1.54        link#3             UHS         lo0
So, what's wrong in my setup?
listhor
I'm bumping it up. Can anybody explain me following:
    description: igb1-zarządzanie
    status: active
    description: LAN4-Zasoby   options=6403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6>
    inet 172.16.1.3 netmask 0xffffffc0 broadcast 172.16.1.63
    status: active
and
I mean igb1 (untagged network) hijacks one of IP addresses of igb2 (tagged network).
In the meantime igb1 IP address (172.16.0.9) also works - it's GUI address...
What's going on here?
Kcaj
You are talking about a tagged network, where are your virtual interfaces for each VLAN?
Confirm your switch is setup correctly first
listhor
I've been considering jumbo frames as potential source of my problems. But on the other hand, everything else (Synology NAS, cameras, raspbpi, docker containers and wifi clients) has no problems at all. If nothing helps, I will try to change everything to default 1500.
I've changed today my setup to vlans (had to set unifi switch port to trunk mode):
igb0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
    description: LAN3
    status: no carrier
    status: active
    description: Dla Samba
    status: active
    status: active
    status: active
    groups: lo
bridge0: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
    ether 02:11:2a:4b:ab:00
    nd6 options=1<PERFORMNUD>
    groups: bridge
    root id 00:00:00:00:00:00 priority 0 ifcost 0 port 0
vlan11: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 9000
    description: Zasoby
    options=600303<RXCSUM,TXCSUM,TSO4,TSO6,RXCSUM_IPV6,TXCSUM_IPV6>
    status: active
    vlan: 11 vlanpcp: 0 parent interface: igb2
    groups: vlan
I have no idea where bridge0 interface came from - I haven't set it up manually and it's not visible in GUI.
Routing table:
Routing tables
Internet:
default            172.16.1.1         UGS      vlan11
172.16.1.0/26      link#8             U        vlan11
172.16.1.2         link#8             UHS         lo0
172.16.1.3         link#8             UHS         lo0
172.16.1.5         link#8             UHS         lo0
Could default routing has something to do with "floating" main GUI IP? But my main concern is SMB/Netbios broadcast. Synology's broadcast is rock solid when FreeNAS broadcast disappears after around half an hour after restarting SMB service (Netbios link in Finder doesn't work anymore and already opened connection is invalid)...
Kcaj
Whenever I am troubleshooting I try to minimise things that could be the problem. I have no experience with Jumbo, but to me it doesn't look right that the bridge has an MTU of 1500 between two interfaces with an MTU of 9000. Just disable Jumbo to make your life easier.
Depending on what version of FreeNAS you are on, jail networking is slightly different. Bridge0 would have been created by the system to attach your jail to, because you likely have not instructed it to do otherwise. Look a the jails Network Properties -> Interfaces
listhor
Like I said before, FreeNAS is the only part of my network which has some issues - therefore I would like to investigate it further, prior to changing my whole LAN. I'm on the latest and greatest stable version 11.3-U1.
I've changed configuration from tagged switch ports to trunk ports and setting vlan interface in FreeNAS. Jails connectivity is same in both cases as expected (iocage set ip4_addr="igb2|172.16.1.3/26" vs ip4_addr="vlan11: storage |172.16.1.3/26") but floating of IP addresses has changed. Now on switch side I can see vlan's parent interface toggles its IP between 2 assigned jails:
Is it normal? I'm used to docker's macvlan multiplied interfaces/Mac addresses...
Previously was toggling IPs between GUI and one of jails addresses. Default route is set to subnet, where jails are on, I haven't noticed any change when was set to GUI subnet. Which one is better?
I don't use Windows at all... :cool:
Kcaj
A tagged switch port is a trunk port. Maybe your network hardware has some other terminology!
What do you mean by this then:
I wouldn't be trusting your switch monitoring, it might not know what to do with an IP alias.
listhor
I meant untagged to trunks, I was typing too quick. Unless I completely mixed up definitions ;-)
I use MacBooks (incl. Time Machine) and other Linux based machines with SMB and NFS. Like I said, SMB with Synology doesn't give me a headache.
Anyway, once again I've changed my network settings. I created trunking lagg interface as a base for all data connectivity across my vlans and virtual interface (ESXi, trunk as well) for GUI management. I will test its performance within next days...
    description: LAN3
    status: active
    status: active
    description: Trunk
    status: active
    description: LAN2  options=6403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6>
    status: active
    description: LAN4
    status: no carrier
    groups: lo
lagg4095: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 9000
    description: Trunk  options=6403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6>
    status: active
    groups: lagg
    laggproto lacp lagghash l2,l3,l4
    laggport: igb0 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING>
    laggport: igb1 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING>
    description: Zasoby
    status: active
    vlan: 11 vlanpcp: 2 parent interface: lagg4095
    groups: vlan
vlan15: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
    description: NordVPN
    inet 172.16.5.5 netmask 0xfffffff0 broadcast 172.16.5.15
    inet 172.16.5.4 netmask 0xfffffff0 broadcast 172.16.5.15
    status: active
    vlan: 15 vlanpcp: 1 parent interface: lagg4095
    groups: vlan
