Mauricio Silveira
- Aug 10, 2016
Hi all.
I'm new to FreeNAS, but I'm an experienced sys admin, and I try to improve my knowledge from time to time.
FreeNAS research led me to other topics I never really dived into before such as SATA bandwidth saturation calculations...
I'll give FreeNAS a shot very soon, but I'd like to to have some theory calrified:
From what I've just learned, in a 12-drive array, using an on-board intel 6 port SATAII controller is not enough, so should I better use one SaS6/iR or 2 SaS5/iR controllers to balance the drives over the total 2/3 controllers?
From my POV, theoretically, I should go with onboard intel + 2 x SaS5/iR, amd I right? Or only benchmarking should tell the truth?
I know 1Gbit NIC would be my bottleneck for a single connection, but in a read intense environment, 4x1Gbit LACP for a dozen Virtualization Hosts, my guess is that I or any customer of mine will be happy with the results.
BTW, I was searching for SaS5/iR at local ebay ( mercadolivre in Brazil ), but I only found SaS6/iR and they're cheap, second hand! So, I'd use 2 SaS6/iR instead of 2 SaS5/iR.
