Multipath degraded
GuillermoX
Hi everyone!
We're in the following scenario, and appreciate your help to advance on the solution of the issue:
Our system description:
HW: FreeNAS Certified 4U24 V2
OS: FreeNAS-9.10.2-U5
24 SAS 8Tb // storage pool
2 SATA DOM SSD 32Gb // mirrored boot
1 SSD 240Gb // L2ARC Read Cache
1 SSD 200Gb // ZIL Write Cache
1) We've received an email alert on Dec 20th with the following information:
freenas.local kernel log messages:
> (da33:mpr0:0:62:0): READ(10). CDB: 28 00 04 93 3e a9 00 00 20 00
> (da33:mpr0:0:62:0): CAM status: SCSI Status Error
> (da33:mpr0:0:62:0): SCSI status: Check Condition
> (da33:mpr0:0:62:0): SCSI sense: MEDIUM ERROR asc:11,0 (Unrecovered read error)
> (da33:mpr0:0:62:0):
> (da33:mpr0:0:62:0): Field Replaceable Unit: 0
> (da33:mpr0:0:62:0): Command Specific Info: 0
> (da33:mpr0:0:62:0): Actual Retry Count: 123
> (da33:mpr0:0:62:0): Descriptor 0x80: f7 2d
> (da33:mpr0:0:62:0): Descriptor 0x81: 00 2f bf 0c 00 a0
> (da33:mpr0:0:62:0): Error 5, Unretryable error
> GEOM_MULTIPATH: Error 5, da33 in disk8 marked FAIL
> GEOM_MULTIPATH: da9 is now active path in disk8
> (da9:mpr0:0:19:0): READ(10). CDB: 28 00 04 93 3e a9 00 00 20 00
> (da9:mpr0:0:19:0): CAM status: SCSI Status Error
> (da9:mpr0:0:19:0): SCSI status: Check Condition
> (da9:mpr0:0:19:0): SCSI sense: MEDIUM ERROR asc:11,0 (Unrecovered read error)
> (da9:mpr0:0:19:0):
> (da9:mpr0:0:19:0): Field Replaceable Unit: 0
> (da9:mpr0:0:19:0): Command Specific Info: 0
> (da9:mpr0:0:19:0): Actual Retry Count: 123
> (da9:mpr0:0:19:0): Descriptor 0x80: f7 2d
> (da9:mpr0:0:19:0): Descriptor 0x81: 00 2f bf 0c 00 ad
> (da9:mpr0:0:19:0): Error 5, Unretryable error
> GEOM_MULTIPATH: Error 5, da9 in disk8 marked FAIL
> GEOM_MULTIPATH: all paths in disk8 were marked FAIL, restore da33
> GEOM_MULTIPATH: da33 is now active path in disk8
> (da33:mpr0:0:62:0): READ(10). CDB: 28 00 17 c1 a0 b9 00 00 01 00
> (da33:mpr0:0:62:0):
> (da33:mpr0:0:62:0): Descriptor 0x80: f7 1f
> (da33:mpr0:0:62:0): Descriptor 0x81: 01 01 68 0c 00 99
> GEOM_MULTIPATH: all paths in disk8 were marked FAIL, restore da9
-- End of security output --
2) We've checked on the web GUI and noticed the status of DEGRADED multipath on Storage/View Multipaths, also checked on the console with:
# gmultipath status -s
multipath/disk1   OPTIMAL  da34 (ACTIVE)
multipath/disk1   OPTIMAL  da10 (PASSIVE)
multipath/disk8  DEGRADED  da33 (FAIL)
multipath/disk8  DEGRADED  da9 (ACTIVE)
multipath/disk16   OPTIMAL  da32 (ACTIVE)
multipath/disk16   OPTIMAL  da8 (PASSIVE)
(resumed output)
Also on the Alert System on the web GUI:
CRITICAL: Dec. 20, 2020, 12:24 a.m. - The following multipaths are not optimal: disk8
3) The output of zpool status shows the pool ONLINE but with scrub repaired data:
# zpool status
  pool: datos
 state: ONLINE
  scan: scrub repaired 128K in 12h50m with 0 errors on Sun Dec 20 12:50:56 2020
        datos                                           ONLINE       0     0     0
          mirror-0                                      ONLINE       0     0     0
            gptid/4267f34f-47bf-11e7-af51-0007433c9d20  ONLINE       0     0     0
            gptid/42eabbff-47bf-11e7-af51-0007433c9d20  ONLINE       0     0     0
          mirror-1                                      ONLINE       0     0     0
            gptid/4351b1c6-47bf-11e7-af51-0007433c9d20  ONLINE       0     0     0
            gptid/43b65fc5-47bf-11e7-af51-0007433c9d20  ONLINE       0     0     0
          mirror-2                                      ONLINE       0     0     0
            gptid/44297dae-47bf-11e7-af51-0007433c9d20  ONLINE       0     0     0
            gptid/44915638-47bf-11e7-af51-0007433c9d20  ONLINE       0     0     0
          mirror-3                                      ONLINE       0     0     0
            gptid/45078510-47bf-11e7-af51-0007433c9d20  ONLINE       0     0     0
            gptid/4576239b-47bf-11e7-af51-0007433c9d20  ONLINE       0     0     0
          mirror-4                                      ONLINE       0     0     0
            gptid/45e345bc-47bf-11e7-af51-0007433c9d20  ONLINE       0     0     0
            gptid/46512b37-47bf-11e7-af51-0007433c9d20  ONLINE       0     0     0
          mirror-5                                      ONLINE       0     0     0
            gptid/46c03cba-47bf-11e7-af51-0007433c9d20  ONLINE       0     0     0
            gptid/4728a4ee-47bf-11e7-af51-0007433c9d20  ONLINE       0     0     0
          mirror-6                                      ONLINE       0     0     0
            gptid/4799e412-47bf-11e7-af51-0007433c9d20  ONLINE       0     0     0
            gptid/5afa7c7a-47c0-11e7-af51-0007433c9d20  ONLINE       0     0     0
          mirror-7                                      ONLINE       0     0     0
            gptid/bf445c67-47bf-11e7-af51-0007433c9d20  ONLINE       0     0     0
            gptid/bfb100c9-47bf-11e7-af51-0007433c9d20  ONLINE       0     0     0
          mirror-8                                      ONLINE       0     0     0
            gptid/c643dd7f-47bf-11e7-af51-0007433c9d20  ONLINE       0     0     0
            gptid/c6afeca0-47bf-11e7-af51-0007433c9d20  ONLINE       0     0     0
          mirror-9                                      ONLINE       0     0     0
            gptid/cd711e67-47bf-11e7-af51-0007433c9d20  ONLINE       0     0     0
            gptid/cdda6714-47bf-11e7-af51-0007433c9d20  ONLINE       0     0     0
          mirror-10                                     ONLINE       0     0     0
            gptid/2066e757-47c0-11e7-af51-0007433c9d20  ONLINE       0     0     0
            gptid/20d14e0e-47c0-11e7-af51-0007433c9d20  ONLINE       0     0     0
        logs
          gptid/edcb224a-47c0-11e7-af51-0007433c9d20    ONLINE       0     0     0
        cache
          gptid/db611e37-47c0-11e7-af51-0007433c9d20    ONLINE       0     0     0
        spares
          gptid/b8eafac2-4a16-11e7-b7f6-0007433c9d20    AVAIL
          gptid/3129c309-9728-11e7-b00d-0007433c9d20    AVAIL
errors: No known data errors
  pool: freenas-boot
 state: ONLINE
  scan: scrub repaired 0 in 0h0m with 0 errors on Tue Dec 22 03:45:10 2020
        freenas-boot  ONLINE       0     0     0
            ada3p2  ONLINE       0     0     0
            ada2p2  ONLINE       0     0     0
4) The SMART information output we receive from smart_report.sh script for all disks:
########## SMART status report summary for all SAS drives on server FREENAS ##########
|Device|Serial                  |Temp|Start|Load  |Defect|Uncorr|Uncorr|Uncorr|Non   |
|      |Number                  |    |Stop |Unload|List  |Read  |Write |Verify|Medium|
|      |                        |    |Count|Count |Elems |Errors|Errors|Errors|Errors|
|da0   |VLH85Z3V                |  37|   53|  1415|     0|     0|     0|     0|     0|
|da1   |VLJ5PDEV                |  36|   53|  1413|     0|     0|     0|     0|     0|
|da2   |VLH6TE1V                |  37|   52|  1413|     0|     0|     0|     0|     0|
|da3   |VLHE11MV                |  35|   53|  1415|     0|     0|     0|     0|     0|
|da4   |VLH96KWV                |  35|   53|294160|     0|     0|    42|     0|     0|
|da5   |VLHE40LV                |  32|   53|  1417|     0|     0|     0|     0|     0|
|da6   |VLHE3HRV                |  38|   53|  1818|     0|     0|     0|     0|     0|
|da7   |VLJ4Y0AV                |  39|   53|  1416|     0|     0|     0|     0|     0|
|da8   |VLJ3WBMV                |  40|   53|  1421|     0|     0|     0|     0|     0|
|da9   |VLHE11RV                |  38|   53|  1419|     2|     5|     0|     0|     0|
|da10  |VLHE5MWV                |  37|   53|  1609|     0|     0|     0|     0|     0|
|da11  |VLGSGP4V                |  32|   52|  1415|     0|     0|     0|     0|     0|
|da12  |VLHE12WV                |  39|   53|  1414|     0|     0|     0|     0|     0|
|da13  |VLHA85NV                |  40|   52|  1503|     0|     0|     0|     0|     0|
|da14  |VLHJDRPV                |  40|   52|  1416|     0|     0|     0|     0|     0|
|da15  |VLHJDH8V                |  39|   52|  1415|     0|     0|     0|     0|     0|
|da16  |VLJ5PJ8V                |  36|   52|  1419|     0|     0|     0|     0|     0|
|da17  |VLH14ZEV                |  33|   53|  1414|     0|     0|     0|     0|     0|
|da18  |VLHE0VKV                |  38|   52|  1543|     0|     0|     0|     0|     0|
|da19  |VLH977VV                |  39|   53|  1415|     0|     0|     0|     0|     0|
|da20  |VLH961TV                |  39|   21|    56|     0|     0|     0|     0|     0|
|da21  |VLH7U1KV                |  38|   53|  1417|     0|     0|     0|     0|     0|
|da22  |VLHJDP4V                |  36|   52|  1414|     0|     0|     0|     0|     0|
|da23  |VLH9E7EV                |  34|   53|   663|     0|     0|     0|     0|     0|
And the output of smartctl -a for the affected device da9:
# smartctl -a /dev/da9
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Vendor:               HGST
Product:              HUH728080AL4200
Revision:             A907
Compliance:           SPC-4
User Capacity:        8,001,563,222,016 bytes [8.00 TB]
Logical block size:   4096 bytes
LU is fully provisioned
Rotation Rate:        7200 rpm
Form Factor:          3.5 inches
Logical Unit id:      0x5000cca260501128
Serial number:        VLHE11RV
Device type:          disk
Transport protocol:   SAS (SPL-3)
Local Time is:        Tue Dec 29 11:50:33 2020 ART
SMART support is:     Available - device has SMART capability.
SMART support is:     Enabled
Temperature Warning:  Enabled
SMART Health Status: OK
Current Drive Temperature:     38 C
Drive Trip Temperature:        85 C
Manufactured in week 36 of year 2016
Specified cycle count over device lifetime:  50000
Accumulated start-stop cycles:  53
Specified load-unload count over device lifetime:  600000
Accumulated load-unload cycles:  1419
Elements in grown defect list: 2
Vendor (Seagate) cache information
  Blocks sent to initiator = 4439804951396352
Error counter log:
           Errors Corrected by           Total   Correction     Gigabytes    Total
               ECC          rereads/    errors   algorithm      processed    uncorrected
           fast | delayed   rewrites  corrected  invocations   [10^9 bytes]  errors
read:          0     1463         0      1463    1113501     124796.107           5
write:         0        2         0         2     500375      16175.706           0
verify:        0        0         0         0    2640440          0.000           0
Non-medium error count:        0
5) Also, today we've received an email alert with a lof of these messages repeated:
> mpr0: mpr_user_pass_thru: user reply buffer (64) smaller than returned buffer (68)
> mpr1: mpr_user_pass_thru: user reply buffer (64) smaller than returned buffer (68)
> mpr0: mpr_user_pass_thru: user reply buffer (48) smaller than returned buffer (52)
Do you suggest to change the disk? Ww've noticed some uncorrected errors, and other errors corrected on the disk
We've seen on other similar posts in this forum, that suggests to run gmultipath restore to clear the FAIL status. It's OK to run that command and see how it evolves?
Thanks in advance for your comments and support.
Best regards,
Chris Moore
Later, after the problem is cleared, you might want to seriously consider an OS upgrade. There have been many improvements.
Chris Moore
Sorry it took me so long to look at your post, I was interrupted, but above appears to be the most important part...
Yes. It appears that both interfaces on the disk were marked "FAIL" and that is usually pretty final. Are you familiar with how to locate the failed drive?
I would also be looking at a possible replacement for da4.
Because you have a pool of mirrors, which does not allow for multi drive failure, I would take no chances. When a drive faults, it should be replaced.
Even if you have a backup or two, a pool failure would result in downtime.
Chris Moore
In a terminal window, you can use the command sesutil locate da9 on to blink the drive light for locating the failed drive.
You can use the command sesutil locate all off to turn the locate light off after the drive is removed.
Please ask if you have any questions.
GuillermoX
Hi, thanks for answering, don't worry about the delay. Good to know about that part.
Yes, I have all the hard drives labeled on the server, so it's easy to locate them by the serial number.
Yes, we take a look at the values for that disk and doesn't looks good....thanks for the suggestion.
OK, thanks. I will replace them then. I have a question regarding this point, because we have 2 spare disks (I'm attaching the volume status configuration were you can see the 2 spare drives disk14/da20, disk24/da23).
I was thinking in the following approach:
- Mark the disks to be replaced as OFFLINE (one at the time), and after that, replace them with the available spare disks.
- Remove the failing drives
- Purchase 2 new drives and leave them installed as spare
But, we have a lot of trouble (and delay of months) to get stock of this kind of drives in our country, so I was thinking in leaving the removed failing drives as spare just in case there's another more critical drive failure...it's possible to reuse them or should we clear the metadata first in some way?
Thanks for your comments.
Best regards
GuillermoX
Great, thanks. We've never used that command to identify the disks before.
GuillermoX
OK, thanks for that suggestion also. What version do you suggest to upgrade to? Should we consider something special regarding this upgrade? Currently this is our only production server and without space to backup everything in another storage, so it's a critical to keep it up and running asap after any intervention.
Chris Moore
The precautions you might need to take depend on what tasks your server is handling for you. How are you using the system?
No backup... You might want to invest in a backup system. Not having a backup would be scary.
You should not try to go from 9.10 direct to the latest release. Here is a link to where you can download the manual update tar files:
While you might be able to skip some versions, out of an abundance of caution, I would suggest going through each of these major versions one at a time, checking that all settings have migrated over and all functions are still working between upgrades.
I understand that you must be cautious as it is the only server, but upgrades are important because of bug fixes and security updates.
Chris Moore
You would need to clear them of data before they could be re-introduced into the pool. Also, putting a drive that is already failing back into a pool doesn't exactly make sense to me. The drive at da4 might be usable, but the drive at da9 appears to have significant problems. You might try testing them in a non-production system. Also, I am an advocate of keeping spares out of the server so they are not accumulating power on hours when they are not needed. I have my spares in a storage cabinet across the hall from my server room and bring them to the server as needed.
GuillermoX
I think I forgot to attach de spare disks detail. There it goes.
GuillermoX
I understand, and it's clear, I agree. The system is being used as a File Server for video processing and storage.
Regarding the updates, that would be in another instance, first we need to solve this issue.
GuillermoX
Maybe we can change or current approach to this one (as you mention, in the current situation, is not useful to have the spares consuming POH). In fact, we though that the spares we had were hot spares...There are any possibility to configure the available disks as hot spares, to be automatically used to replace a disk when another disk fails?
Thanks.
