Ugh, there's the whole terminology thing, "bind to the IP address" again. I'm assuming what you mean is that when you bind to an IP address that's assigned to a specific card, traffic goes in/out that card.
To expand for the OP: You can certainly "bind to an IP address" in UNIX but in FreeBSD it's an abstraction that makes no guarantees as to the physical handling of the traffic. This is really useful in many environments for lots of stuff. For example, you can get network redundancy for a server using OSPF by putting your service addresses on a loopback interface, and then advertising that into your interior gateway protocol using OSPF or some other IGP. The address that all external traffic uses isn't configured on ANY ethernet interface. Userland applications "bind to the IP address" just like it was an alias (or the primary address) on an ethernet interface... anyways, point is, application level binding is pretty much not closely coupled to physical interfaces. FreeBSD has a rich set of network interfaces that it supports, including point to point links (PPP, SLIP, parallel port cable), ATM, etc., and the networking subsystem presents it all as an abstraction to the userland. So of course since a lot of the IP configuration is driven by what's defined for physical interfaces, this leads to operational and terminology confusion.
Basically, for the issue at hand, there are two key bits:
Input traffic from an Ethernet network to a host is controlled by ARP. The ARP subsystem publishes MAC addresses in response to requests from an ethernet network, and this happens infrequently (meaning far less than once a second). ARP controls packet ingress. The system ARP table maintains a list of learned and published addresses, and when an ARP packet is received, the system compares it to the system's interfaces and responds with the MAC address of the interface. Now this process works pretty much the way the OP would expect, but it can be subverted. For example, if I have a server with two interfaces, em0=192.168.1.1/24 and em1=192.168.1.2/24, and I set a client's ARP table with a manual entry for 192.168.1.1 pointing at the MAC address of server's em1, the traffic for 192.168.1.1 from client to server enters server on em1. And everything works fine. The UNIX networking layer doesn't think this odd or anything, even if you have a userland app that is bound to 192.168.1.1, it all works.
Output traffic to an ethernet network is controlled by the routing table, and the routing table is keyed by destination IP address. Basically when you do a "route get ip.ad.dr.ess" the system does a routing table lookup, similar to what happens when a packet is output. The source IP address isn't considered because IP routing happens based on destination. So as long as the routing code picks AN interface that's on the network in question, packets will be delivered, and that's pretty reasonable.
If you want to have multiple interfaces on a network, you should use link aggregation.
If you want to have multiple IP addresses on a network, you should define ifconfig aliases.
You can do other things, but then you're fighting the way it was designed, and then it may not work as you expect.
