My environment is VMWare ESXi hosts. Storage is Dell EMC. We are about to add in a Freenas. Each ESXi host as six nics, two are dedicated to storage in an MPIO config:
Storage Nics:
Nic 1: 192.168.0.0/24 VLAN100
Nic 2: 192.168.1.0/24 VLAN200
VMWare iSCSI nic port binding IS enabled (I am in the midst of confirming with VMware if I need the port binding since i have separated the subnets... im a little confused about this). We are looking to add our Freenas server into the environment and I want to set up MPIO. The Freenas has a four port nic. One of these ports will be assigned to each respective subnet as described above.
Question 1:
I have been reading here in the forums that if I have iSCSI port binding set in ESXi, I cannot use MPIO with Freenas. Just want to confirm if this is true? If so, I guess I should look at LACP with NFS instead of iSCSI?
Question 2:
From the ESXi server, both of those storage connections connect to separate switches. There is a link between the switches. Our network admin is worried that if our ESXi servers have connections to each switch, there is a link between the switches, and then each switch has a connection to the Freenas we will run into a switching loop. I'm assuming the Freenas is treated as a singular "target" although there are multiple connections to it and therefore this problem is mitigated?
Question 3:
Is there a definitive guide to setting up MPIO for Freenas? I see reference of configurations with two portal groups, and others with one portal group with multiple IPs added. What is the best way to go?
I imagine I'll get blasted for asking stupid questions but thanks anyway for any help/advice you can give.
Thanks!
Alex
Storage Nics:
Question 1:
Question 2:
Question 3:
Thanks!
Alex
