Moving plugins to Scale
bmartin3k
I am in the process of moving my pool from a core server to a newer one running scale.
I plan on exporting and importing the pool. This pool contains my iocages and jails.
Is there an easy way once its imported, I can use my configs for those plugins with the apps in scale.
That's arguable... there is a way... I wouldn't call it easy.
It's also different depending on which apps you installed and how you set the storage for them...
TrueCharts... if you chose PVC (the defaults), you can use the method described here to access the PVC storage and copy your config or whatever in there:
That may also work for Official apps where you chose PVC.
If you used host path, you'll need to consider permissions making sure to transfer the right files to the right path on the host, then using chown to give the right user and group IDs ownership of the newly placed files.
All that without telling you where to even find the needed config or data for your apps... I'll leave that as homework for you.
