ReggiePerrin
- Jul 20, 2011
Hi
I'm new to Freenas/Unix so please bear with me if this appears to be a really Noob question :)
Firstly this is a great product, my HP microserver arrived yesterday and within an hour I had Freenas up and running; no fuss, no problems... The longest part was waiting for the Freenas image to burn to the USB key.
Scenario/plan:-
I'm migrating a lot of DVD rips from a WHS v1 server into a temp 2TB volume I've created on Freenas, I then want to physically move a 2TB drive from the WHS server and put it into the Freenas server, create a single drive ZFS volume on this drive and then copy everything across from the temp volume.
Finally blitz the temp volume, setup a RAID1 ZFS mirror and selectively copy the video and nfo files from the former WHS drive (the single drive ZFS volume) to this new volume.
[Sorry if this is as clear as mud, but I want to move a lot of data :) ]
The question:-
After I move the data from the WHS box onto the Freenas box, and to remove the network as a bottleneck, can I then ssh onto the freenas box and use the UNIX cp command to copy data between volumes by referencing the relevant /mnt/'volume name'/'Dataset' directories?
Logically I don't see this as being a problem, but as my knowledge of Unix can best be described as dangerous, I thought I would just double check first.
thanks in advance
Reggie
Scenario/plan:-
The question:-
thanks in advance
Reggie
