furicle
- Feb 14, 2012
Hi All
I've outgrown my original one disk set up, so I installed a port multiplier card and an external drive box.
(FreeNAS 8.3.0)
I used zfs send | recv to copy the data to the new drive array, and repointed the file shares to the new external array.
Now I want to pull that internal single drive. Everything system related should be on the USB stick AFAIK, so I thought the only remaining reference to the internal drive is the couple of local users home directories.
When I try to alter that path with the 'modify users' option, it always errors with Home Directory Mode This field required - when that field is filled in? I don't get what it's trying to say.
Someone clue me in?
And is there anything else I need to look at before I pull that drive?
(FreeNAS 8.3.0)
Someone clue me in?
